Home    Trouble Shooting
Trouble Codes
Click on Trouble Code for detailed troubleshooting tree and diagnostic tips
            After making a change to repair the problem, disconnect the orange wire by the battery to clear the code(s) from memory and reconnect.  Then recheck for any codes.
12        Normal Diagnosis function.  Not a trouble code.
13        Open Oxygen Sensor Circuit
14        Coolant Sensor.  Temperature reading high
15        Coolant Sensor.  Temperature reading low
21        TPS (Throttle Position Sensor) High Signal Voltage
22        TPS Low Signal Voltage
23        MAT (Manifold Air Temperature) Low Temperature Indicated
24        VSS (Vehicle Speed Sensor) Circuit Fault
25      MAT High Temperature Indicate
31        Wastegate Solenoid Circuit Fault
32        EGR System Fault
33        MAF (Mass Air Flow) Sensor.  High Flow Indicated
34        MAF Sensor.  Low Flow Indicated
41        Cam Sensor Circuit Failure
42        C3I EST or Bypass Circuit Failure
43        Electronic Spark Control System Failure
44        Lean Exhaust Indicated
45        Rich Exhaust Indicated
51        Prom Error
52        Calpak Error
55        ECM Error
