Author Topic: 04 Silverado - rusty parts hauler  (Read 9080 times)
Re: 04 Silverado - rusty parts hauler
« Reply #15 on: January 20 2023, 03:23:09 PM »
Back saver 9000 - so far it's been worth every penny.
« Reply #16 on: January 20 2023, 06:45:53 PM »
My little experience with one suggests tht it might be worth more than gold, or catalytic converters!
« Reply #17 on: January 21 2023, 10:36:22 PM »
That reminds me while it’s apart I need to get the numbers off the cars and see what they are worth. Might pay for headers/ypipe lol
« Reply #18 on: January 22 2023, 09:34:18 AM »
LOL, I gave about three to some guy if he would haul off some other junk for me.  Another dumb thing I could have made some money from but hate going to places and getting screwed on stuff I sell
« Reply #19 on: February 01 2023, 10:17:44 AM »
I fired it up Sunday - let it run for 30 seconds. Instant 60+psi of oil pressure, and I couldn't believe how quiet it was with all the exhaust leaks fixed and a quiet valve train. It's way too cold to heat cycle it in the barn at the moment, so that'll wait until all the maintenance is done.
Yesterday I changed the ball joints, the idler arm, and the pitman arm. I've still got to install inner/outer tie rod ends, sway bar bushing/endlinks, and then service the transmission and differentials since I'm sure it hasn't been done ever.
« Reply #20 on: February 01 2023, 07:31:29 PM »
About to be too nice to use in bad weather.
« Reply #21 on: February 02 2023, 04:50:07 PM »
https://youtu.be/8u69oiDxgtQ
Just need to change the trans fluid/filter and check the toe. Like a dumbass I forgot to measure first so I guess I’ll see where it is and how well I can get it to drive. Might need to go for an alignment
« Reply #22 on: February 02 2023, 06:00:57 PM »
set up some string across (and parallel to) the rear tires and across the front tires.  Set the toe on the front within the two strings
« Reply #23 on: November 27 2023, 05:57:19 PM »
Black Friday I was bored - so I cut the muffler off and put a Hooker Aerochamber on it. Now that it sounds good - it's time to tackle the leaking rear main seal.
About 5 hours in and it's torn down to the point that I can fix the rear main seal lol
« Reply #24 on: November 27 2023, 06:02:01 PM »
and a short exhaust clip for fun - https://youtu.be/6HQpZwAizRQ
« Reply #25 on: November 27 2023, 06:10:51 PM »
Sounds good to me. Six hours to go !
« Reply #26 on: November 27 2023, 06:53:51 PM »
Probably be done this weekend - the transmission to transfer case gasket won't be here until Friday.
The transmission dipstick tube was stuck pretty good and the transmission was seized on the dowels. I dropped a few fbombs but it wasn't as bad as I thought it'd be.
« Reply #27 on: December 01 2023, 02:31:36 PM »
Just got back from a test drive - other than reinstalling the transfer case solo, it was pretty easy. It's snowing so I even got to test 4wd
« Reply #28 on: December 01 2023, 06:53:19 PM »
Now you have time to work on the next problem.  :rofl: :rofl:
« Reply #29 on: December 01 2023, 09:34:45 PM »
Tomorrow - new headlights and a muffler for the wife’s civic. Sunday an old friend would like me to help look at his wife’s car it has an exhaust leak.
