Author Topic: nocooler's firechicken thread  (Read 271122 times)
« on: October 03 2014, 09:55:23 PM »
Forum's slow so I figured I'd talk about my firechicken.
I've been fighting to get this car to hook for sometime. It'd go 1.5's but not consistently and it should go easy 1.4's. I thought it was due to the mass of the new twin disc, then wondered if the slicks were toast, then started thinking about the rear shocks.
So today I tore the drivers shock out - it's a QA1 Gen F 24 way double adjustable. Both compression and rebound adjusted fine. Put it back on and checked the suspension how much drop I had and found this
« Reply #1 on: October 03 2014, 09:58:15 PM »
I guess I should explain - it's got 1.25" of extension - not nearly enough for a stick shift car.
Damn thing has been topping out the shocks and unloading - or at least that's what I'm hoping.
Did get a good pass in last week. Faceplated T56 ftw!
http://youtu.be/INxMTMPUTMo?list=UUgPl5n0VjubnUfBu65BQE9Q
« Reply #2 on: October 03 2014, 10:00:28 PM »
Here is what a McLeod RXT twin disc clutch looks like - and a QTP bellhousing to save my feet
« Reply #3 on: October 04 2014, 10:29:33 AM »
Nailed him on the tree...nice work! Care to let us in on the complete engine build?
« Reply #4 on: October 04 2014, 10:53:43 AM »
It's a pretty simple setup
Stock bottom end LS1
Patriot CNC'd LS6 heads with dual springs
231/237 .589./595 112 LSA cam
Fast 78mm intake/Throttle body
36lb GM ASA injectors
Lid/Fasttoys Ramair
Ebay headers, ypipe
Magnaflow catback with cutout
Nitrous Outlet plate - usually hit it with 100 or 150 - not spraying in the video.
« Reply #5 on: October 04 2014, 10:57:16 AM »
Aftermarket fuel management system?
« Reply #6 on: October 04 2014, 10:57:57 AM »
Stock PCM tuned by me with HPTuners  :rock:
« Reply #7 on: October 04 2014, 11:01:28 AM »
Stock PCM. I'm liking this. :)
« Reply #8 on: October 04 2014, 11:06:30 AM »
Differential/driveshaft/transmission upgrades?
« Reply #9 on: October 04 2014, 11:16:47 AM »
I always admire that brings a stick to an auto fight!  Car runs really well :cheers:
Brad, you ought build one of these....be like a bike with 4 wheels :)  You can shortcut the process because he has learned a lot as to what works and what does not.
He has been playing with this one for a few years now.  He got sidetracked for awhile recovering from his accident but he seems to be going full bore now.  I really like the car.
« Reply #10 on: October 04 2014, 11:23:15 AM »
I have my R1 and my 85 IROC up for sale. I bookmarked HPTuners...
« Reply #11 on: October 04 2014, 11:32:35 AM »
Jeremy, what have you done to make the tranny survive?  Does not sound like you are taking it easy on the shifts.  I always had a bad habit of not letting off the gas and not using the clutch very much...some of these new trannies don't hold up to what I would consider normal racing...
« Reply #12 on: October 04 2014, 11:34:30 AM »
I don't know anything about it, but, several of my friends down in Houston use it and like it.
« Reply #13 on: October 04 2014, 11:46:12 AM »
120 mph...it comes on on top end! 100 hp shot must turn it into a beast
« Reply #14 on: October 04 2014, 12:52:05 PM »
Trans was built buy liberty gears here in MI. It's faceplated and has a viper mainshaft. All parts were heat treated and shot peened.
With it being faceplated the box is un-synchronized 1st thru 4th. It still needs you to clutch it but only enough to get it out of gear and then you slam it into the the next @ WOT. It's clunky and loud around town, but with some double clutching and practice most people wouldn't even notice.
The rear is a Midwest Chassis (MWC) fab 9" w/4.56 gears and a tru-trac diff, 31 spline axles. ABS still functions. It's got MWC's short torque arm, spoon's antiroll bar, umi lower control arms, and a 3.5" PST Aluminum driveshaft.
QA1 single adjustable coil overs out front and double adjustable out back.
100 shot it's been 130mph - 150shot, 132mph. Best et with the T56 is like a 10.6@131.
I've been fighting a traction issue this year with the new twin disc clutch. It hits the tires harder do to more mass and it's instant burnout if I go WOT on the 2-step and dump the clutch. I've tried everything shock settings, suspension mount points and tire pressure. I even put the 4.56 gears back in the thing from the 4.11's.
I think I found the issue - being the shocks don't have enough travel on extension.
