Author Topic: cold air intake  (Read 67060 times)
cold air intake
« on: July 28 2014, 10:36:28 AM »
Made this over weekend. 3 inch exhaust pipe, sheetmetal shroud/box with 1/4 in slit hose around edges. Cut out area where stock filter housing was mounted to open to air under nose of car. Probably wont really do anything but it was a rainy day
  • Moderator
Re: cold air intake
« Reply #1 on: July 28 2014, 01:59:32 PM »
Without a lid it probably don't do much....
But the IAT reading will tell you if the air temp is lowered.
Offline instro84
Re: cold air intake
« Reply #2 on: August 06 2014, 12:17:22 AM »
nice looking project.
Offline puzzledfox
  • Newbie
Re: cold air intake
« Reply #3 on: February 19 2017, 06:07:30 PM »
Did installing a cold air intake improve your ride's  fuel efficiency and horsepower?
  • Moderator
Re: cold air intake
« Reply #4 on: February 20 2017, 01:25:46 AM »
Mileage will drop as the temps go lower.
Without some probes it's hard to tell if pressure in that box was higher or lower than normal.
If higher it probably won't make measurable power until you hit about 250MPH.
Offline puzzledfox
  • Newbie
Re: cold air intake
« Reply #5 on: February 21 2017, 10:18:46 AM »
Thanks for enlightening me. Thinking of getting one for my ride.
Re: cold air intake
« Reply #6 on: February 26 2017, 10:39:07 AM »
Nice work!
Offline aminga
  • Chicks Dig the Power Bulge
Re: cold air intake
« Reply #7 on: February 28 2017, 09:32:19 AM »
I did something similar for different reasons.  I got tired of having the A/C hose rub on the filter and rub a hole in it.  Figured if the hose could rub a hole in the filter then the reverse was possible too (Giggity).
My goal was to get the filter over toward the fender and away from the hoses.  As a plus I picked up a bung for the IAT.
I didn't build in anything to box it off.  I guess it helps some with IAT but sitting still in traffic it still climbs to over 120.
  • Moderator
Re: cold air intake
« Reply #8 on: February 28 2017, 01:44:46 PM »
That's what I like about my MAF pipes.  They have a second articulation point you can 'steer' them down after clearing the up pipe and IAT plug.  With that additional adjustment they can miss the alternator pulley and go under the A/C lines without flexing them.
I always hated how normal pipe kits only allow for a slight height adjustment and the filter just has to land wherever it lands.
Offline Grumpy
Re: cold air intake
« Reply #9 on: April 26 2017, 11:20:53 AM »
Ill bet it works better than having a lid on it  :player: Been there an done it  :rock:
