The Bastard Child Buick Board
yes there is a TA 61 but they are not THAT common... I think Brent over in Yorba Linda is running one. If you only dynoed at 300 hp you have way more in the 49...
Yes, of course!
Quote from: "Top Speed @ Sat Oct 28, 2006 2:16 pm"Yes, of course!
Is there such a thing as a "TA-61"? I know that there is a TE-61. Do the TA & or TE 61 have any real gonads at street level. Low level rpm, like pulling from start?
Quote from: "Gary Wells @ Sat Oct 28, 2006 1:41 pm"Is there such a thing as a "TA-61"? I know that there is a TE-61. Do the TA & or TE 61 have any real gonads at street level. Low level rpm, like pulling from start?They do, and them some, when matched with the correct torque converter. TE's are better.
Quote from: "Recklessrob @ Sat Oct 28, 2006 9:34 pm"Quote from: "Gary Wells @ Sat Oct 28, 2006 1:41 pm"Is there such a thing as a "TA-61"? I know that there is a TE-61. Do the TA & or TE 61 have any real gonads at street level. Low level rpm, like pulling from start?They do, and them some, when matched with the correct torque converter. TE's are better.-----------------------------Rob:You did it. You said the magic no-no word for me. I can get by without a converter with a 60, but not a 61, huh? The buck stopped there.
I have heard that the bb turbos spool quicker, but if you thinkk about it, the only real difference would be the difference in friction. I think that I had better take my chances with a TA-60. I don't trust advertising hype all that much. I am suprised that I did not hear a fight with you guys about me staying on racing fuel for a while, but I believe and have heard that that alky can make more power, but the only difference would be the extra cooling effect from the alky sprayed into the airstream. PSM (Pete Tomka) fresh/cold air package going on shortly, then on to the dyno. My last dyno was 300 RWHP & 360 RWTQ, and I am going to guess that with the bigger injectors, new 60 chip, & cold air package maybe 320 RWHP & 385 RWTQ. Any other guesses?
Quote from: "Gary Wells @ Sun Oct 29, 2006 4:15 pm"I have heard that the bb turbos spool quicker, but if you thinkk about it, the only real difference would be the difference in friction. I think that I had better take my chances with a TA-60. I don't trust advertising hype all that much. I am suprised that I did not hear a fight with you guys about me staying on racing fuel for a while, but I believe and have heard that that alky can make more power, but the only difference would be the extra cooling effect from the alky sprayed into the airstream. PSM (Pete Tomka) fresh/cold air package going on shortly, then on to the dyno. My last dyno was 300 RWHP & 360 RWTQ, and I am going to guess that with the bigger injectors, new 60 chip, & cold air package maybe 320 RWHP & 385 RWTQ. Any other guesses?------------------------------------Gary, what are you getting for AFR readings, and scanner data ? Alky will make a big improvement on those numbers. BB turbos kick ass, but are very expensive.
