Author Topic: What TR mods do you plan to do.. That you ALREADY have the parts for?  (Read 5869 times)
I mean.. things you want to do, and already have the parts to do so..
I'll start...
    Front frame braces
    replacement Ramchargers fan
    Caspers fan harness for above fan
    2x anti-rattle kits for doors
    New passenger-side header
    new copper exhaust gaskets
    VDO tach
    VDO oil/water gauges
    Scanmaster
    Replacement heater hoses
    Vacuum break setup
    New Fuel filter
    new rear brake hardware
And yes, I have all of the parts in had for these repairs/upgrades.. Sad, isn't it?
Offline TSM Girl
Re: What TR mods do you plan to do.. That you ALREADY have the parts for?
« Reply #1 on: October 18 2006, 09:59:15 PM »
1) Front Mount
2) TA 54 Turbo
3) Slotted Rotors
4) GN1 Heads
So far......... more parts to come as soon as the garage is done.... :mad;
Donna
"Stupid people should NOT breed!"
Offline 87natty
« Reply #2 on: October 18 2006, 10:00:38 PM »
Hmm...
Front mount intercooler (Just need pipes bent)
40# injectors
New valve springs (80#)
Timing set
Kenne Bell oil pump booster
Boxed lower control arms
AutoMeter carbon fiber boost and oil gauges
Offline Be4u
« Reply #3 on: October 18 2006, 11:29:07 PM »
I'm cought up. My alky is leaking somewhere...ne ed to find that problem. I guess when I get my afpr that'll be the only thing I have to put on.
Brian, if I can get off my lazy ass I'll be ablke to bring you a power plate in a week or so...along with the headers.
Save the bumper fillers!
Move to Canadia!
Offline Ttype83
« Reply #4 on: October 19 2006, 12:38:07 AM »
For the 86
New valve springs
maybe exhuast off the 83
DP
Bleed the stupid brakes again
83
replace front bumper support
rear brake job (have all parts)
Make a 3" single shot exhuast
fix header leaks
Get some damn MT DR's
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Offline Recklessrob
« Reply #5 on: October 19 2006, 01:15:26 AM »
Ahhh, lets see.
tt chip
60# inj
billet FPR
Precision TE-44
Comp 206 roller
forged crank
forged rods
JE pistons
Stainless up pipe
109 block with 3 billet mains (all but rear)
ARP studs
Tach
Silicone coolant hoses
silicone IC and up pipe hoses
ported lower intake
reworked iron heads w/ oversized int valves
new T top interior moldings
new center caps
braided oil cooler lines
braided turbo feed line
braided turbo drain line
March pullies
misc. stereo components
boost valve
...and I know I'm probably forgetting some stuff.
Rob
Offline 87natty
« Reply #6 on: October 19 2006, 04:17:36 AM »
Oh no shit! You have a new motor!
Robert, thanks I totally forgot!
Offline granitestategn
« Reply #7 on: October 19 2006, 11:01:25 AM »
Rob,
I thought I was the king of "parts on shelf", but I think you've got me beat.
If I can remember them all.....
GT61P turbo
3500 stall L/U TCS 9X11
timing set, roller button, gaskets, etc
new oil pump and shims
biggie oil filter adapter
new water pump
the rest of my alky system, switches, relays, nozzles, etc
new up-pipe
MAFT Pro
Innovative BO2 set-up for MUFTI Pro
3-bar MAP
Full Throttle boost solenoid for MAFT Pro
new power antenna mast
new rear brake shoes, soft long shoes
new Champion valve covers and gaskets
JVC AM/FM cassette w/CD control
JVC 12-disk CD changer
new rear speakers ( I don't remember brand)
new Brute Force u-joints
new intercooler scoop
new TT alky chip
16" GTA mesh wheels and tires
Autometer boost gauge
Casper's knock gauge
two gauge pod for console
Kirban's GNX bushings
Ummmm...that's all I can remember, I'm sure there's more.
12.98 @ 104
Offline Racer X
    • http://www.hotrodbuick.com
« Reply #8 on: October 19 2006, 11:54:26 AM »
I just finished building a new shop for a hot rod builder here in Anaheim. I did the work for free and in return we are going to completely re engineer the chassis on the Buick with lots of custom stuff. We are going to get started after he gets back from SEMA.
Stay tuned...
2008 Charger SRT-8
2009 Challenger R/T
any questions?
Offline Be4u
« Reply #9 on: October 19 2006, 01:26:21 PM »
Looking through the lists I notice that there are alot of easy things to do.....and I thought I was lazy. lol
RX, looking forward to seeing what y'all come up with.
Move to Canadia!
« Reply #10 on: October 19 2006, 01:32:01 PM »
Well....I have the following New parts ready to go:
PTS Extreme radiator
Braided oil cooler lines from John's Performance
Dual 12" Spal fans
Caspers Fan harness with delay
RJC 325 Megacooler
Rebuilt Power steering pump
RJC PS pump pulley
PS hoses
PS cooler
PS reservior w/cap
FlowKooler water pump
RJC billet idler pulley
Caspers headlight hotwire
ARP SS timing cover and water pump bolts
Left headlight bezel
Plastic dash cover
And when all that is finished, I have more plans in the works!!
Offline ledzeppac
« Reply #11 on: October 19 2006, 05:07:28 PM »
nothing, burn it to the fucking ground hopefully.
I need to do the headliner/ get my gauge, dash lights working...
« Reply #12 on: October 19 2006, 05:30:21 PM »
Quote from: "ledzeppac @ Thu Oct 19, 2006 4:07 pm"
Quit yer bitchin and just get it done!  :supz:
Offline Recklessrob
« Reply #13 on: October 19 2006, 05:43:15 PM »
Yeah, what he said. :jerkit;
Rob
Offline ledzeppac
« Reply #14 on: October 20 2006, 08:31:40 PM »
not bitching jsut wishful thinking...
I dont have the energy or time...
