scanmaster quit
Topic: scanmaster quit (Read 803 times)
Shimy87
PSI: 2
scanmaster quit
June 07 2024, 11:57:47 AM »
Back again guys! SM just quit working other day. Been trouble shooting and heres what I got. Start car and it displays start up info, then shows --- --- then goes to sleep so its not recieving a signal from ECU. I read where after it goes to sleep you can ground signal wire and it should "recycle" start up display....it dosent.
I also read where som ECU's fail in the area where it send signal to ADL port, and also the low speed fan relay and TCC solonoid. I have some new relays coming, the old ones seemd to work as they should.
Is there a way to test the signal wire to see if it is sending data, or do I need another SM to figure that out?
as always, thanks for any help!
Re: scanmaster quit
June 07 2024, 01:31:35 PM »
I think I would drop a note to Bob Bailey
ULYCYC
Turbo Street Modified
PSI: 4
Re: scanmaster quit
June 07 2024, 03:31:02 PM »
You can also try on Turbo Tweaks site.
https://www.turbotweaksupport.com/index.php
Shimy87
PSI: 2
Re: scanmaster quit
June 07 2024, 07:33:38 PM »
Thanks guys!
daveismissing
Re: scanmaster quit
June 08 2024, 10:07:36 AM »
If you had an oscilloscope you could see transitions on the ALDL wire ( not helpful I know)
Who doesn't have a spare ECM?
My experience is that Bob pretty much fixes them for life.
Scoobum
Re: scanmaster quit
Reply #5 on:
June 11 2024, 06:59:03 PM »
When you get it figured out...hard wire it.
Shimy87
PSI: 2
Re: scanmaster quit
Reply #6 on:
June 12 2024, 11:27:19 PM »
It turned out to be the computer wire that goes from the logger to the wiring bar, it was just slightly pulled out and that was it. Strange it came loose on its own.
Re: scanmaster quit
Reply #7 on:
June 13 2024, 08:16:57 AM »
Looks like Brad guessed right 😀
Just a Six?
OK Now who Farted??
PSI: 2
Re: scanmaster quit
Reply #8 on:
June 19 2024, 11:30:13 AM »
Glad I took a look at this thread it reminded me that mine has either a bad ground or the chip needs to come out & get re seated. It scrolls thru all the 50's codes then 40's & 30's but always starts with the 50's.
I'll do that & take the PL out & see what it says when it cools down out here it's Hot this week!
Grumpy
PSI: 4
Re: scanmaster quit
Reply #9 on:
June 22 2024, 10:22:16 AM »
I have never had one fail.
scanmaster quit
