HighWay Stars
Author Topic: Oil Pump Question  (Read 8974 times)
Offline Hill1430
Oil Pump Question
« on: October 24 2023, 12:18:13 PM »
Like you said Steve, on to the next problem. I am changing the oil to put the car to bed for the winter. When I removed the oil filter these two parts feel out. What should I do? The car has always had good oil pressure. Just drove it yesterday.
1987 Grand National Work in progress
2019 Shelby GT350
Re: Oil Pump Question
« Reply #1 on: October 25 2023, 09:26:25 AM »
I don't recognize those pieces.  You say that they fell out of the filter?
How long is that black piece?  I don't think I have ever seen anything like that in a filter being used as an anti drainback or bypass valve.
It looks like the head of the black piece would fit into the metal piece which would close off "flow". But it would have had a spring that kept it closed normally
« Last Edit: October 25 2023, 09:48:20 AM by Steve Wood »
Offline Hill1430
« Reply #2 on: October 25 2023, 11:41:24 AM »
I’m sorry, I should be more specific. I guess it is the pressure relief valve in the oil pump housing, if the filter were to get plugged.  Can I just reinstall? Could packing the housing with Vaseline for initial start have caused this? It is out of the hole at the top of the picture.
2019 Shelby GT350
« Reply #3 on: October 25 2023, 03:19:41 PM »
I believe you could do that, but there should be a spring that prevents the plunger from moving until the back pressure gets to about 20 psi.  As I recall, the metal part is staked to keep it in position to hold the assembly in place.
Offline Hill1430
« Reply #4 on: October 25 2023, 06:34:43 PM »
The spring is still inside. I messaged Earl Brown who I purchased the part from. He said to reinstall and puts a couple light stakes on the edge to help hold it. Thank you for your advice.
2019 Shelby GT350
« Reply #5 on: October 25 2023, 06:41:39 PM »
That's what I would do :)
