My GN lives and thank you to the forum
2
Topic: My GN lives and thank you to the forum (Read 19175 times)
Hill1430
Bone Stock
Boost n00b
July 20 2023, 11:21:11 PM »
I want to thank everyone who has answered my questions over the last couple of years. I finally started my car yesterday. I was surprised it started right off. Have a couple of minor leaks to address, but overall running good. My scanmaster reads BL of 124-128 at idle depending on which time I start it. TPS is .42. Now the bad, I have Mal code 43. Bad ESC or wiring. I can get a new ESC Module from NAPA for $220. Is that the way to go, or does someone have a better suggestion? I have included a few pictures of the progress. Again, thank you all!!
1987 Grand National Work in progress
2019 Shelby GT350
Re: My GN lives and thank you to the forum
July 21 2023, 01:09:26 AM »
My first thought is that it's not the module. I would think it's wiring.
Try going thru the trouble shooting here.
Glad to hear the progress!
https://www.vortexbuicks-etc.com/code_43.htm
Last Edit: July 21 2023, 09:17:11 AM by Steve Wood
Hill1430
Bone Stock
Boost n00b
July 21 2023, 09:22:27 AM »
Thanks, this gives me a place to start. Could a knock sensor installed too tight cause this?
2019 Shelby GT350
July 21 2023, 11:33:28 AM »
don't think so. That might cause false alarms but not a trouble light. Note, I did not go back and read the tree I linked
Looking at the tree, I would check for continuity between the knock sensor and E on the esc. A good ground at D. 8+ volts at B7 at the ecm when the key is turned to Run. And 12 volts at B when the key is in run.
Last Edit: July 21 2023, 11:42:08 AM by Steve Wood
Hill1430
Bone Stock
Boost n00b
July 21 2023, 01:17:34 PM »
I can't get to it till Monday, but I will check those first and get back to you.
2019 Shelby GT350
Hill1430
Bone Stock
Boost n00b
Reply #5 on:
July 29 2023, 04:33:52 PM »
Ok Steve, I have no continuity between E and the ESC. I have a good ground at D. I have 12 volts at B. At B7 on the ECM I am not sure how to check. What i did was try to check the back of the plug while plugged in, don't think my probe could get in there. I installed a knock sensor from Casper's which attaches to the wire at B7. I tried to get a reading at the solder joint, but was getting a reading of .067. where should I go from here?
Also I replaced the knock sensor while I had the engine out.
2019 Shelby GT350
Reply #6 on:
July 29 2023, 10:55:59 PM »
E is the blue wire that runs directly to the knock sensor. Set your meter to ohms, put one probe on the connector that is E and the other one in the connector at the knock sensor. The meter should go ding and read 000. If it does, you have continuity.
B is okay as it shows power with the key on.
As far as B7 is concerned, you should have over 8 volts with the key on and the same if the engine is running. Did you try with the engine running? If you don't, I would unsolder the alarm from the wire and then see what you have.
If you changed the knock sensor, you may have to try the old one if the above checks out.
Hill1430
Bone Stock
Boost n00b
Reply #7 on:
July 30 2023, 09:55:47 AM »
I have to leave town for a week. I will try all of those items when I get back. I do have an unrelated question, behind the instrument cluster, upper right hand side is a 25 amp fuse, see photo. Is this related to the factory alarm system this car has?
2019 Shelby GT350
Hill1430
Bone Stock
Boost n00b
Reply #8 on:
August 09 2023, 04:22:22 PM »
I checked the wire to the knock sensor and it is good. I think I might have a bad knock sensor. I found a video to bench test the sensor with it mounted in a vise hooked to a voltmeter. When you hit the vise it should give a reading over one volt, it does not. Does this sound right? If the sensor is bad, would that cause pin B7 to not show voltage?
2019 Shelby GT350
Reply #9 on:
August 10 2023, 09:31:55 AM »
This version of the chart says that if tapping by the sensor does not work, then it could be a bad connector or a bad sensor if I read correctly.
Reply #10 on:
August 10 2023, 09:34:30 AM »
The above chart is a continuation of the trouble code checking chart.
Hill1430
Bone Stock
Boost n00b
Reply #11 on:
August 10 2023, 04:13:16 PM »
I have a new AC Delco knock sensor coming. As soon as it gets here I will continue diagnostic with the chart.
2019 Shelby GT350
Hill1430
Bone Stock
Boost n00b
Reply #12 on:
August 14 2023, 11:17:35 PM »
All right I am an IDIOT! I rechecked all my wiring and I found that when I installed my Caspers knock guage I wired it wrong. I hooked the signal wire to the ground terminal and vice versa. So I fixed that. Still getting code 43. The only scan tool I have is the Scanmaster. So following the flow chart I do not get the rpm drop unplugging the the esc. I also don't get the rpm jump if I remove the Jumper wire at terminal E. It all seems to point to a bad esc. NAPA shows a new one, I'm ready to try that.
Do you think it would hurt the car to drive it easy until I chase this down? I want to put some miles on before I install the front clip.
2019 Shelby GT350
Reply #13 on:
August 15 2023, 09:23:31 AM »
LOL
No, I don't think it will hurt to drive it easy. I am not sure it will have much power because I think it may keep the timing reduced to a low level but I am not sure about that. Give it a try and if it runs okay, it will be fine.
Hill1430
Bone Stock
Boost n00b
Reply #14 on:
August 15 2023, 11:35:30 AM »
Hopefully the new ESC will fix the problem.
2019 Shelby GT350
2
