Author Topic: Help with turbo mounting and vacuum lines  (Read 6853 times)
Offline Hill1430
« on: June 17 2023, 11:02:02 PM »
I am finally getting my car back together. I purchased a new stock replacement turbo from GN1 Performance. After getting it installed the inlet neck doesn’t line up with the intercooler very well. Did I mess up somewhere? The intercooler is down as far as possible. Is it a turbo problem? Should I have had my original rebuilt? Or am I making something out of nothing?
Also would it be a problem to replace a hard vacuum line with hose?
1987 Grand National Work in progress
2019 Shelby GT350
Offline 1KWIKSIX
Re: Help with turbo mounting and vacuum lines
« Reply #1 on: June 18 2023, 06:51:42 AM »
Re-clocking the turbo should help however you might also want to consider installing an offset silicon hose.
They even have reducing offset hoses if it’s needed for 3 different sized hoses in your case.
 https://hpsperformanceproducts.com/products/hps-silicone-offset-off-center-coupler-air-intake-hose-turbo-black-blue
https://hpsperformanceproducts.com/pages/hps-reinforced-silicone-reducer-coupler-transition-hoses
« Last Edit: June 18 2023, 03:23:43 PM by 1KWIKSIX »
Offline Hill1430
« Reply #2 on: June 18 2023, 11:43:58 AM »
I did not know you could clock the turbo. Thank you so much! I will consider both options. Anyone have a suggestion on the hard vacuum line?
2019 Shelby GT350
Offline 1KWIKSIX
« Last Edit: June 18 2023, 03:29:40 PM by 1KWIKSIX »
« Reply #4 on: June 18 2023, 05:00:14 PM »
Yes, clock it and use silicone hose
Offline Hill1430
« Reply #5 on: June 18 2023, 10:39:01 PM »
I have everything lining up now. Thank you all, I appreciate the knowledge when I need advice!
2019 Shelby GT350
« Reply #6 on: June 18 2023, 10:58:32 PM »
Good!
« Reply #7 on: June 23 2023, 07:08:37 PM »
Silicone vacuum hose is what I use
https://hpsperformanceproducts.com/products/hps-high-temp-silicone-vacuum-hose-tubing-coolant-overflow-tube-htsvh
Dave what size is the hose 1/4" or something like that? I need to add a couple check valves for HVAC & cruise control & Dorman has a few options.
Offline 1KWIKSIX
« Reply #8 on: June 24 2023, 07:00:46 AM »
Here’s a link that lists all the different sizes of vacuum hoses needed for our cars.
You’ll have to scroll down quite a ways to find the list but it’s quite extensive
https://www.turbobuick.com/threads/scanmaster-g-readings.480870/
« Reply #9 on: June 24 2023, 12:55:31 PM »
Thanks Dave I'll take a look but does it really matter that some are larger than others? 1/4 & 5/16 are pretty close in size?
Offline 1KWIKSIX
« Reply #10 on: June 25 2023, 07:14:18 AM »
I doubt that it’s really critical ……as long as it’s a snug fit , I’d think you’ll be golden 👍
« Reply #11 on: June 27 2023, 02:26:45 PM »
Yup, just loosen the backing bolts on the Compressor housing and rotate. :cheers:
