Author Topic: Battery Cable / frame clip wanted  (Read 8705 times)
Offline 1KWIKSIX
« on: February 07 2023, 05:04:36 PM »
Looking for the battery cable hold down clip attached to the passenger side front frame.
Broke it while removing the battery cables .
Can anyone e help out a Buick Brother?
Offline gnonyx
Re: Battery Cable / frame clip wanted
« Reply #1 on: February 07 2023, 07:36:54 PM »
If you can't find an replacement, then for now you can place the top broken cable strap back and use cable zip ties to hold it down.
Offline 1KWIKSIX
« Reply #2 on: February 08 2023, 03:50:50 PM »
Thought about that too ( as a last resort).
Thanks for your suggestion 👍
Offline 1KWIKSIX
« Reply #3 on: February 10 2023, 05:20:02 PM »
Found one!
Got one coming next week.
Thanks to all for your help
« Reply #4 on: February 10 2023, 06:06:48 PM »
Good deal!
Offline gnonyx
« Reply #5 on: February 10 2023, 10:09:51 PM »
Found one!
It's amazing how rare pieces that are hard to find shows up in needs. congrats
Offline 1KWIKSIX
« Reply #6 on: February 11 2023, 03:23:11 PM »
Have since found a source for this scarce & unique GM clip.
In case anyone else ever needs this clip, I’ll save you the trouble of scouring the internet in your search to find it.
Here’s a link:
Happy Motoring!
stage1restorat ions.com
https://www.stage1restoration.com/product/battery-clamp/
« Last Edit: February 16 2023, 04:12:01 PM by 1KWIKSIX »
