Author Topic: 04 Silverado - rusty parts hauler  (Read 17053 times)
Online nocooler
« on: January 08 2023, 02:58:02 PM »
So I've been dealing with an oil pressure issue with my truck since I've bought it and decided it's time to stop messing around and fix the POS.
Basically, once the oil temp gets warm enough the oil pressure starts dropping, and then the valve train starts getting very noisy.  On a hot day, I can haul my car to the track about an hour away and by the time I get there the truck is getting loud, and when I leave about the time I pull in the driveway she starts clattering. But if you shut it down and let it rest for 5-10 minutes you can restart it and it's good to go until the oil temp climbs again. It happened on a parts run last week and while it hasn't been a problem yet - I want to get it resolved.
So here are a couple of pictures of the tear-down.
Online nocooler
Re: 04 Silverado - rusty parts hauler
« Reply #1 on: January 08 2023, 03:05:44 PM »
Of course, the center/drag link was a complete pain in the ass to remove. One outer tie rod is junk for sure - probably do a pitman arm and idler arm while it's apart.
But I found the issue - the sump was full of sludge and the pickup was fully submersed in it. Basically, once the sludge got warm enough to become viscous would clog the oil pump pick-up. tube.
I cut the oil filter open and I was surprised it's not packed full of glitter, so I'm gonna clean it up and put it back together.
« Reply #2 on: January 08 2023, 04:25:46 PM »
All I have is, WOW!
Online nocooler
« Reply #3 on: January 09 2023, 02:51:11 PM »
Waiting on parts to show up.
I ordered inner/outer tie rod ends, pitman/idler arm, sway bar end links, and an oil pan gasket.
I'm almost tempted to do the control arm bushings and ball joints then the frontend would be fresh but that's a lot of work to put into this POS.
It'll probably need an alignment once I get the new tie rods on - I guess we will see how it drives once it's back together.
Online nocooler
« Reply #4 on: January 11 2023, 03:52:31 PM »
Other than the vaseline in the driver's valve cover it doesn't look terrible.
« Reply #5 on: January 11 2023, 03:54:16 PM »
that is not an inviting???????????????
Online nocooler
« Reply #6 on: January 11 2023, 05:10:31 PM »
I should have saved some and mailed it to you!
« Reply #7 on: January 11 2023, 06:20:38 PM »
Is that the result of water and grease?
Online nocooler
« Reply #8 on: January 11 2023, 06:36:48 PM »
It looks like it may have castech heads on them that crack and weep coolant. That explains the entire mess IMO.
« Reply #9 on: January 11 2023, 08:00:50 PM »
Had to look that one. Marked down as what I learned today
Online nocooler
« Reply #10 on: January 13 2023, 03:38:29 PM »
Heads are off, lifters are out - and it's just a sloppy mess all around. Up next I'm gonna pull the cam and check it for wear. PCV system was functioning, the intake had a mess of goo in it and it was starting to remove the carbon from the chambers/pistons.
« Reply #11 on: January 13 2023, 08:32:17 PM »
The term "glutton for punishment" was created for you.  Next step will be the addition of two more wives to your family
Online nocooler
« Reply #12 on: January 16 2023, 11:29:27 AM »
Just chipping away at it. Parts will be here in the next couple of days
« Reply #13 on: January 16 2023, 04:05:04 PM »
What are you doing about the leaky heads?  A Cadillac pill in the radiator?
Online nocooler
« Reply #14 on: January 16 2023, 04:09:46 PM »
Leaky heads are in the scrap pile. I’m gonna use the set I picked up a couple weeks ago.
