Author Topic: Help With No Start  (Read 3494 times)
Offline Joel Russo
  • Harrisburg, PA
Help With No Start
« on: December 08 2022, 08:02:46 PM »
Help with no start.
I’ve followed the steps outlined in the Vortex Buicks pages, and here’s where I’m at…
87 GN, 15 K miles, TT 60 lb injectors and 5.7 chip with 255 Walbro in tank recently.
Car sat for 2 years without starting.
I have spark, 32 lbs pressure on the rail, injector pulse, but no start.
Is it possible the injectors are clogged?
Where do I go next?
'87 GN, 14K miles, TE-60, 60lb inj, TT 5.7, 2800 10" NL conv, RJC 3" DP, Pypes exh w/ Race Pro, Walbro 255 w/Hotwire.
Re: Help With No Start
« Reply #1 on: December 08 2022, 08:19:24 PM »
It's very possible.  Spray some  starting fluid (or flammable carb cleaner/brake kleen) into the intake and see if it tries to run.
If it does, take an extension and rattle it with a hammer against the base of each injector-not hard enuf to break the injector.  Sometimes this will get them unstuck altho the gas today can form so much jelly that this may not work.
Offline Joel Russo
  • Harrisburg, PA
« Reply #2 on: December 09 2022, 05:43:25 AM »
Thanks Steve!
Sprayed some brake kleen in the plenum, and it started and ran for a few seconds then shut off.
« Last Edit: December 09 2022, 06:18:40 AM by Joel Russo »
« Reply #3 on: December 09 2022, 09:35:28 AM »
Sounds like they are stuck or glued up and not letting any fuel thru
Offline Joel Russo
  • Harrisburg, PA
« Reply #4 on: December 09 2022, 10:29:23 AM »
I tapped on the bases like you described.
Any suggestions now?
« Reply #5 on: December 09 2022, 11:54:03 AM »
Have them cleaned is my only thought. That's assuming you have injector pulse as seen on a noid light or even on a test light if you can see that fast. 🙂
Offline Joel Russo
  • Harrisburg, PA
« Reply #6 on: December 09 2022, 03:42:39 PM »
Checked injector pulse with a noid light, all good.
Tapped the crap out of them and I finally got it to run for a a little then stalled out.
Started up and stayed running.. put 10 gal of fresh 93 and drove it a good 20 miles and it didn’t skip a beat.  She’s a handful..
Thanks for your help Steve.
« Reply #7 on: December 09 2022, 04:24:45 PM »
pour some good injector cleaner like Techron in the tank...and may help clean them...   or, just fresh gas may do the job as it has lots of cleaner in it as well
Glad it finally  got to working!
