Author Topic: Project WTF White Trash Fox  (Read 38169 times)
Re: Project WTF White Trash Fox
« Reply #45 on: December 29 2022, 11:01:32 AM »
Figures I installed the doors with handles and both of the handles are broken - damn Fords!
« Reply #46 on: December 31 2022, 04:38:27 PM »
Today I traded the rear seats out of the mustang for a tubular k-member, stock control arms/spindles/brakes, and some shocks with a coil over kit and qa1 coil over springs.
The kmember has been modified at one point, the drivers side mount had a brace cut out and then a plate put in plate -but the price was right  :rock:
« Reply #47 on: January 01 2023, 09:55:30 AM »
The way stuff multiplies in your shop would seem to suggest you are good at breeding rabbits! :cheers:
« Reply #48 on: January 01 2023, 06:41:45 PM »
I may have a problem
« Reply #49 on: February 10 2023, 11:41:48 AM »
Since the truck is done - I moved the mustang back to the operating table.
K-member fit nicely but the coil over spring kit won't work without an adjustable caster/camber plate setup.
I spent a couple of hours trying to fight the stock coil springs back into place. There isn't enough room to remove the spring compressor I have once it's all assembled, and there isn't enough weight on the front of the car to use a jack to compress them. Almost pissed me off enough to order the caster/camber plates!
Also I broke my favorite S&K 1/2 drive ratchet again doing the ball joints on the truck. I could have fixed it again for $40 but I started looking around. For a little more money I could have a new Tekton, Proto, or Milwaukee. I went with the 18" Milwaukee for $75. So far it seems really nice - but we will see how it holds up.
« Reply #50 on: February 22 2023, 02:59:02 PM »
I've made a little more progress.
Traded the front coil-over spring setup for a nice aluminum radiator.
I decided I didn't like the engine mounts so I made these work.
« Reply #51 on: February 22 2023, 09:16:55 PM »
Looks like they should work.
« Reply #52 on: March 30 2023, 07:38:26 PM »
Just some updates.
« Reply #53 on: March 30 2023, 07:43:05 PM »
more
« Reply #54 on: March 30 2023, 07:45:04 PM »
and more....
« Reply #55 on: March 30 2023, 09:12:02 PM »
If I need to borrow some wire, I will stop by. I have my own side cutters.
« Reply #56 on: April 02 2023, 03:03:55 PM »
Is that a DIN rail? :)
Offline Recklessrob
« Reply #57 on: April 25 2023, 11:23:19 PM »
 :rock: Built Ford Tough with Chevy Stuff...
Rob
« Reply #58 on: April 27 2023, 03:29:16 PM »
I was making good progress on the wiring until my brother's SUV decided to eat its bearings. The 5.3 that I helped him do a AFM/DOD delete, cam swap last year. The engine was filthy inside and he didn't want to do all the extra work to pull the pan. I guess it's easier to change engines - we've got a 6.0 to replace the 5.3 so it should be a noticeable upgrade.
I figured I'd share my frustrations with you the last picture is me loosening the torque converter bolts, that was the only way I could get them.
« Reply #59 on: April 28 2023, 09:03:55 AM »
Man, you are one hell of a brother! :cheers:
