Author Topic: cruise control  (Read 2289 times)
cruise control
« on: September 09 2022, 12:23:35 PM »
When I set the cruise it is "surgey" I have a direct line from vacume block to a y that goes to the ball and cruise unit. Should there be a check valve in that line? wouldnt think that would cause a surge as its in vacume, not boost. The speedo needle is not smooth, waves around a bit, maybe a 5mph swing cause the cable probably needs to be lubed but its a bitch to get to.
any help?
Re: cruise control
« Reply #1 on: September 09 2022, 01:06:37 PM »
I am pretty sure that it needs a check valve...the one on the firewall was a check valve.
