Author Topic: 1985 Grand National Update  (Read 8283 times)
Offline Big Dawg
Re: 1985 Grand National Update
« Reply #15 on: September 14 2022, 12:05:26 PM »
 :cheers:
Thanks
« Reply #16 on: September 14 2022, 12:32:21 PM »
nice!!
Offline Big Dawg
« Reply #17 on: September 14 2022, 11:57:05 PM »
Thanks for the kind words Steve!!
I got the valve covers and the top of the intake sanded down, and I must say they look good!!
Got the 60lb injectors and fuel rail installed along with the shield on the intake.
Got the FelPro Gaskets delivered today and you were correct Steve, had to trim just little bit on both sides of the gaskets on the intake side of the gaskets....was n't too bad. Torqued them down to spec 44 inch pounds is what I had. The Engine is finally starting to come along.
A.
Offline Big Dawg
« Reply #18 on: September 14 2022, 11:57:44 PM »
« Reply #19 on: September 15 2022, 10:31:24 AM »
Incredible work! I love the audio setup. Super clean install.
Offline Big Dawg
« Reply #20 on: September 19 2022, 09:17:33 PM »
Hi guys,
I am just in the middle of connecting all my vaccum lines on my 85 Hot Air and a couple of lines just don't make sense, seems they have been routed incorrect, or i just can't seem to make out the diagrams i found.
First there are 2 hoses that are coming out of the Solenoid Wastegate Valve,  I know one goes to the actuator yellow in the diagram attached, but there is one beside it as well and it doesn't show clearly where that one ends up going, it was T' d off into the PCV vaccum line, but in the diagram it shows no T's in the PCV vaccum line.. I was thinking it actually goes to the vaccum distribution  box on throttle body, but not sure.
The second vaccum line that has me a bit confused is there is a thin black hose that comes over from the passenger fender and goes to what I'm thinking is the cruise control. This line had a T adaptor and one end was attached to the vaccum box on throttle body, but when I look at the diagram it only shows the pcv vaccum line and a line out of the EGR valve control plugged into the vaccum box.
I am hoping someone can guide me in the right direction.
Thanks alot,
A.
« Reply #21 on: September 19 2022, 10:20:24 PM »
https://www.vortexbuicks-etc.com/8485_trouble_shooting.htm
Check the vacuum line diagram at the bottom. Does it help?
Offline Big Dawg
« Reply #22 on: September 20 2022, 12:54:43 AM »
That's exactly what I needed...thank s Steve
« Last Edit: September 20 2022, 03:21:04 AM by Big Dawg »
« Reply #23 on: September 20 2022, 09:26:13 AM »
I knew when I put that on my site, some one would need it some day!  LOL
