Author Topic: Plug wires  (Read 8589 times)
Re: Plug wires
« Reply #15 on: September 01 2022, 08:05:56 AM »
Steve, there's a list on here somewhere of all the cars that utilize the ignition module we use...except they're NA. I think I posted the numbers of a couple NA ones I had and you posted the vehicles they were off of. I tested them at the track and they were fine...but keep in mind I didn't run gobs of boost which throws more stress on the ignition system. The aftermarlet RPM gauge I used worked with all the NA ones I tested. I never looked at the stock RPM gauge to see if it worked with them, so maybe that's what some were refering too.
Re: Plug wires
« Reply #16 on: September 03 2022, 04:02:27 PM »
new ignition module came in...BINGO!!! runs smooth as silk now, accelerates cleaner and seemingly better also.  Holy crap was that a goose chase but sucess :atbeer: :atbeer:
Re: Plug wires
« Reply #17 on: September 03 2022, 10:21:47 PM »
I would have lost a bet on this point.  Live and learn :).  Glad that cleaned it up👍
