Author Topic: Power antena  (Read 4928 times)
Power antena
« on: August 20 2022, 07:26:06 PM »
Anyone make a replacement? I know you can rebuild the mast cable but the motor is shot also.
Re: Power antena
« Reply #1 on: August 20 2022, 08:20:59 PM »
My son told me he thought the roadmaster antenna looked a lot like the one in the Regal. Might be able to get one from a wrecking yard. Easier than the regal as it is in the back in the trunk.
Offline Big Dawg
Re: Power antena
« Reply #2 on: September 05 2022, 02:28:26 PM »
I bought this antenna from Summit......it was almost identical to the stocker other than having no mounting bracket. I just removed it off the stocker and riveted it the new one.
Offline Big Dawg
Re: Power antena
« Reply #3 on: September 05 2022, 02:30:49 PM »
Here are some more pics of the replacement
Re: Power antena
« Reply #4 on: September 06 2022, 03:00:47 PM »
Thanks, yes I got the same one from Amazon, same thing with the bracket but works like a charm
