Author Topic: Alky pump  (Read 3225 times)
Alky pump
« on: December 12 2021, 04:40:37 PM »
Do you guys that store car for winter drain alky pump and put windshield wiper fluid in it or just leave it alone? Read alky is hard on seals in the pump????
Offline 1KWIKSIX
Re: Alky pump
« Reply #1 on: December 12 2021, 05:31:15 PM »
What’s Julio recommend ? 🤷‍♂️
Re: Alky pump
« Reply #2 on: December 12 2021, 05:37:15 PM »
Looking at this logically I'd be thinking that the seals are made for alky.
Re: Alky pump
« Reply #3 on: December 12 2021, 05:39:34 PM »
My thoughts also, i thought Juilo recommended it though???
