Do you have an air compressor that you can dial down to 15psi?If so, test your PCV valve to see if it blocks flow into engine. You might be surprised.
I used some red valve train lubricant spray from Comp Cams. Coated everything real good just in case.Prolly not needed but it couldn't hurt.
Fire the whore up!!!!!!!!!!!!!
https://www.vortexbuicks-etc.com/rocker_shaft_assembly.htm
