Zap *STILL* wears Depends
Quote from: Steve Wood on November 11 2021, 10:51:09 PMNo need to touch the white nylon plugs. Just pull the three boltsEither set of locks will work as you are not running a high pressure spring. Only three bucks or so difference in them.Thank You Steve for all of your helpOnce I get the valves springs, retainers, and locks, and start to install them I will post again; if I don't run in troubleHave a nice weekend, Julio
Be sure you order a new thermostat housing while you are at it. Smear a little grease on the rubber seal before you reinstall it.Probably 95% of the people install the ground bundle on the rear intake stud as Brad said. One of my cars is that way and the other one has the Caspers ground relocation kit and also Caspers fusible link relocation kit. Smarter people probably just make their own LOLI have often used this stuff on connectors before reconnecting things https://www.amazon.com/DeoxIT-D5S-6-Contact-Cleaner-Integrated/dp/B0002BBV4G/ref=psdc_3230976011_t2_B00E1QZ01SI have often found these useful when doing wiring projects on cars. https://www.camarocentral.com/1967_1971_Battery_Cable_Junction_Block_With_Nut_p/wir-341.htm I am glad you made me think of them as I should have a few out in the shop and I can use one or two on my station wagon rewiring project. Pretty sad when an old man can improve old Mopar factory wiring by at least a 1000%
You really don't need a hole in the thermostat on a buick
Quote from: Steve Wood on November 17 2021, 01:34:07 PMYou really don't need a hole in the thermostat on a buickI forgot to ask since a while back there was a major discussion about using a 160 degree thermostat or the 180 degree thermostat. 160 keeps the engine cooler as where the 180 keeps the engine warmer as per factory spec.I know this can open a can of worms (per say), but need to know.What do you think?
I agree 180
people do it in numerous ways.I don't recall what we did two or three years ago when William and I put a new set of heads on my GN. But I used to put a very thin smear of silicone around the water ports and once or twice, I put it very thin around the intake ports if I saw any pitting on the surfaces around the port. Also on the ends, of course.I think the gaskets were made to go on dry, but new heads and intake should not have had any pitting, either. I think you will be fine no matter which way you go. Your choice.
We used silicone around the water ports.
