Author Topic: E85 using a Kenne Bell boost a pump  (Read 4550 times)
Offline Recap
« on: October 05 2021, 08:10:32 PM »
So I was considering going to E85 which will require me to upgrade my fuel pump.  The logical choice would be the DW300.  I don't like charish the thought of dropping the tank.  I do have a walbro 255l pump in it now.  Was thinking that maybe a better (easier) option might be a boost a pump.  Any thoughts or opinions on going this route.  I know I'll need injectors and a chip too.  Just trying to get out of dropping the tank if I don't have to.
Re: E85 using a Kenne Bell boost a pump
« Reply #1 on: November 24 2021, 05:32:31 PM »
Leaning an engine out is way worse than dropping a tank for a pump swap.
« Reply #2 on: November 24 2021, 06:02:46 PM »
don't know how much fuel it will take.  I would prefer a DW pump.  The KB controller will certainly give more fuel, but, Personally, I would rather be able to supply it with a simple pump.
« Reply #3 on: November 25 2021, 10:00:43 AM »
Go with the 300 pump. A bigger pump will overwhelm the return line. You'll need a matching E85 chip from Eric. Pump change is a 2 beer job.
« Last Edit: November 25 2021, 10:05:05 AM by Scoobum »
« Reply #4 on: November 25 2021, 10:09:18 AM »
Quote from: Recap
If you don't wanna drop the tank then I have vids on how to change head gaskets.
Offline v6sleeper
  • G-body guru
« Reply #5 on: January 05 2022, 05:29:36 PM »
Minimum 120s and a 450lph or a Hellcat 525 pump and teflon line kit.
87 GN- t-netics hpc,custom 3" dp, champion irons,stage 2 trans ,3021 9.5nl,poston headers ,Atr liquid intercooled, Hemco r plenum
87 Turbo T-  Borg warner,aluminum R-heads,husek trans,E85 Gn-ecu td 1.65 ptc 9.5nl
70 sport wagon 455 stage 1,Gessler alum heads
82 olds wagon Lc2 powered-sold
