lowering the rear
Topic: lowering the rear (Read 1984 times)
Shimy87
PSI: 2
lowering the rear
September 09 2021, 09:12:54 AM »
Im cheap so years ago I cut down the front springs to lower the front about 1 inch. Now with the taller M&H tires on the rear it has to much height in the back, looks silly. Question is, can i cut the backs down the same way to get the back down some. I know i cant cut the one end but the other looks like i can??
Thanks!!
Re: lowering the rear
September 09 2021, 09:29:56 AM »
just use a saw and take a little at a time...saw so the heat does not weaken the spring
most real car guys are cheap....
Shimy87
PSI: 2
September 09 2021, 03:15:35 PM »
thanks Steve!!
lowering the rear
