Well I finally got tired of shifting with the column and took the floor console off to see what's going on. The shifter cable came apart. See pic. Is there a repair procedure you guys have used? I cut some of the plastic sheathing off and the steel cable sheathing does fits back into the plastic retainer. Was thinking I could clamp the retainer over the cable or run a set-screw in through the retainer to hold the steel sheathing? Or is best bet to find a new cable? Thanks!
Thank you gnonyx! Ordered it from Amazon and it should arrive tomorrow. Was installation straight forward - does cable go from trans outer manual lever to shifter or does the steering column come into play?
