Author Topic: O-ring lower oil cooler line at radiator  (Read 2982 times)
Offline xracerx13
  • NOT
  • First Methanol Kits
« on: July 25 2021, 04:38:31 PM »
Is it possible to get just the O-ring for the lower high pressure oil cooler line on the radiator side of the hose?
Joe Tripodi 87 Limited T
Re: O-ring lower oil cooler line at radiator
« Reply #1 on: July 25 2021, 05:28:41 PM »
I'm too old.  I thought that was a flared connection.  Looking at the diagrams, I don't see the o-ring and I don't see one on g body parts or highway stars
It does look like there are a couple in the hose kit from Highway Stars so I guess there is
this looks like the ones that go into the oil cooler adapter side of the hose according to tb.com  Oil line o-ring for the oil lines where they go into the adapter on the front cover: M83248-1-905
« Last Edit: July 25 2021, 05:41:20 PM by Steve Wood »
« Reply #2 on: July 25 2021, 05:51:10 PM »
Yes it has 0-rings.  Saginaw fittings with 0-rings. It's been a long time but I think its the same size as the fuel injector uses'
Offline xracerx13
  • NOT
« Reply #3 on: July 25 2021, 06:55:23 PM »
I must be crazy :icon_eyes:. I don't see any o-rings in that pic but pics are deceiving. I wish it was a fuel injector o-ring. I can get those at advance auto.
What happened was I replaced the radiator with a cold case and now the bottom hose leaks a tad but not dripping. I could have sworn I saw o-rings on it.
Can anyone verify that the o-ring is the same as the fuel injector?
heres the fuel injector o-ring spec...
Felpro ES 70599 - 0.296in Inside Diameter x 0.574in Outside Diameter
« Last Edit: July 25 2021, 07:18:10 PM by xracerx13 »
Offline xracerx13
  • NOT
« Reply #4 on: July 25 2021, 07:38:39 PM »
Steve not sure if these are correct or not but I found an aerospace company that sells them.
M83248/1-905
Inner Diameter: 0.414", Thickness: 0.072", Rubber | Fluorocarbon Elastomer | High Temperature, Fluid, And Compression Set Resistant
« Last Edit: July 25 2021, 07:52:54 PM by xracerx13 »
« Reply #5 on: July 25 2021, 08:40:34 PM »
You can get a 0-ring assortment for $10 from Harbor Freight or Amazon and have plenty of extras for future projects. Or take the hose off and bring it to a auto parts store that make hoses up and I'm sure they will have them.
