Author Topic: getting ready for track  (Read 9167 times)
Re: getting ready for track
« Reply #30 on: August 05 2021, 09:48:21 AM »
Been to the track a couple times a year for the last 6 years. When I first started going the car was in the 14's. If I make it to the track again this year plan on adjusting low gear timing, and manually shifting from 2 to 3.
