Author Topic: Cam card?  (Read 2243 times)
Offline quick72toy
Cam card?
« on: July 13 2021, 07:55:10 PM »
Anyone have a cam card for the Revolution XR1 206/210? Lost mine. Need the Valve timing opening and closing @ 0.050 for Int and Ex.
 Thanks.
Paul
1972 Toyota Celica  87 TR drive train
Motor 30 over, 10/10 crank, HV.oil pump, P&P heads, PTE 44, Hot wired GSS 340, 52lb Siemens, mod ECM, Speedpro 204/214, Dutweiller big neck intercooler, 62 mm TB, Power Plate, Hot wired coilpack    AC CR42’s, Postons headers, MAFTPro,  LC1 WB O2 sensor, Alky kit
Re: Cam card?
« Reply #1 on: July 13 2021, 08:44:38 PM »
You may have to call 'em up and ask Marianne to take a picture of the card if she has one in stock??
Offline quick72toy
Re: Cam card?
« Reply #2 on: July 14 2021, 03:31:26 PM »
Quote from: Steve Wood
Thanks Steve. I called but she doesn't have one. Will have to call again tomorrow morning and talk to Steve to see if he has that info.
Offline quick72toy
Re: Cam card?
« Reply #3 on: July 14 2021, 04:01:01 PM »
FWIW Did some hunting and found this Opening and Closing calculator from Adv duration specs        IO = (.5*AdvIntDur)-Intake Lobe Center        IC = (.5*AdvIntDur)-(180-Intake Lobe Center)        EO = (.5*AdvExhDur)+(2*LSA-ILC)-180        EC = (.5*AdvExhDur)-(2*LSA-ILC)        Add the Intake opening and the Exhaust closing time to get the overlap.        So, FWIW according to this calculator, the 206/210 roller cam timing specs are                     Intake opening -7 BTDC        Intake closing 33 ABDC        Exhaust opening 35 BBDC        Exhaust closing -5 ATDC        -5 overlap
« Last Edit: July 14 2021, 04:17:33 PM by quick72toy »
Offline quick72toy
Re: Cam card?
« Reply #4 on: July 14 2021, 04:04:07 PM »
Sorry cant get this to format
