Author Topic: New Int/Exh Valves & Over-Sized Valves?  (Read 3651 times)
Offline ~JM~
« on: July 09 2021, 04:14:28 PM »
136K miles & the heads are off. Thinking about replacing the valves while I have it apart. Seeking advice on make, material & type of valves to use.
Is there much of an option for larger valves? Doesn't look like there is much room between them.
How often are valve stem seals installed on the exhaust valves?
Offline ~JM~
Re: New Int/Exh Valves & Over-Sized Valves?
« Reply #2 on: July 09 2021, 06:13:20 PM »
Thanks. I'm not having much luck with my searches. The points brought up on the exhaust side interest me. I've been looking at the head casting & feel the exhaust side looks very restrictive.
Offline ~JM~
« Reply #3 on: July 09 2021, 06:14:52 PM »
Vertical pics are the ones that do not turn out well. Same pic as above but turned horizontal.
Offline ~JM~
« Reply #4 on: July 09 2021, 07:06:35 PM »
  :rock:
« Reply #5 on: July 09 2021, 10:33:32 PM »
I forgot how shitty that exhaust port is
Offline ~JM~
Offline ~JM~
« Reply #7 on: July 10 2021, 07:00:29 PM »
