Author Topic: O2 Oxygen sensor  (Read 3193 times)
Offline gnonyx
O2 Oxygen sensor
« on: May 28 2021, 06:58:10 PM »
Hi All, It seems each member claimed one oxygen sensor is better than the ACDelco
Highway stars claimed: AFS-21 ACDelco one wire (non-heated, original equipment) Oxygen Sensor for 1984-1987 Vin 7 Buick Grand National, Turbo Regal, 1987 GNX, and 1989 Turbo Trans Am, supersedes both ACDelco AFS-20 and AFS-22 oxygen sensors.
Yet others claimed Denso is better
Which one is supersedes all?
Offline 1KWIKSIX
Re: O2 Oxygen sensor
« Reply #1 on: May 28 2021, 07:44:41 PM »
I’ve had better luck with the Denso, so have stuck with what works best for me. Each to their own , I guess 🤷‍♂️
Offline gnonyx
« Reply #2 on: May 28 2021, 08:26:39 PM »
I have tried the 1st two types, and the 3rd will be installing:
ACDelco AFS-22
Denso
ACDelco AFS-21
Which part # do you use for Denso?
« Reply #3 on: May 28 2021, 08:50:31 PM »
234-1001
Offline gnonyx
« Reply #4 on: May 28 2021, 10:00:50 PM »
234-1001
Thanks Steve, and have a safe and enjoyable weekend
