Zap *STILL* wears Depends
Time to do something free. Program some additional fuel at idle...try about 5% morePut it in open loop idle if it's not already there
Again, it is important that the injectors be cleaned properly so that they not only spray a proper pattern, but also to insure they all spray the same amount of liquid for a given injector pulse width. When you have them professionally cleaned, each one will come back marked to show how much it sprayed so you can compare them to one another to be sure they are doing what they are supposed to be doing.Having said that, I doubt there is anything wrong with yours. I think you need to adjust your fueling as I suggested above by programming the chip.Here are the various o-ring part numbersNAPA #730-4912 you get 2 of each one and they are correct.NAPA #2-18416 for a package of one of each size.STANDARD MOTOR PRODUCTS SK27 Fuel Rail O-Ring KitSTANDARD MOTOR PRODUCTS SK26 Fuel Rail O-Ring Kitborg warner or neihoff search part # 27478 , its a kit of both o-rings for the fuel railstandard motors brand in a 10 pack.. sk27 feed , sk26 returnFel Pro ES 70599For the FPR to rail connection it is a standard GM injector O-ring.I used to have these saved some place but I googled for the results this timeOh, I still do. From my site http://www.vortexbuicks-etc.com/injectorswap.html
probably because they cost a penny a piece and people tend to screw up them by not using grease on them or such
