Author Topic: Rear End Axle Cover Plate  (Read 2624 times)
Offline gnonyx
« on: May 06 2021, 10:00:37 AM »
Hi All,
Just want to know is it best to install the Fel-Pro gasket on dry or put a thin film of RTV?
Thanks
Re: Rear End Axle Cover Plate
« Reply #1 on: May 06 2021, 01:28:08 PM »
I always used ultra black with the gasket on the 8.5" 10 bolt. 9" just ultra black.
Offline gnonyx
« Reply #2 on: May 06 2021, 06:16:17 PM »
Thanks for the info
Offline Tim Hensley
« Reply #3 on: May 07 2021, 02:37:56 AM »
I like gasket and red wheel bearing grease
DLS 210-210
Champion irons
