Author Topic: hot cold blend door  (Read 8733 times)
hot cold blend door
« on: May 04 2021, 11:50:15 AM »
Well this weekend slid the hot/cold lever over to hot. later go to slid it back to cold and feel some resistance then it slides to cold but no cold air :O looks like the cable connects to a v shaped plastic arm that moves the door. Well the plastic V broke where the cable connects. It also appears you need to remove the entire dash to replace that part :013:
Anyone run into this dilema?
Re: hot cold blend door
« Reply #1 on: May 04 2021, 01:14:33 PM »
« Reply #2 on: May 04 2021, 03:02:20 PM »
Hey Steve, yup thats the culprit. I did some research and found the part on a vendor site. Thanks for the info!!
« Reply #3 on: May 04 2021, 03:43:42 PM »
lucky that one is an easy fix
« Reply #4 on: May 06 2021, 09:09:53 PM »
was a much harder fix before the parts became available
« Reply #5 on: May 06 2021, 09:45:48 PM »
don't you have a 3d printer?
« Reply #6 on: May 12 2021, 08:09:04 PM »
Quote from: Steve Wood
Didn't back then.PLA is not that strong.Would have to beef it up. Sending it out is actually fairly cheap tho
« Reply #7 on: May 16 2021, 03:29:58 PM »
Mine went many years ago & I drilled it out a bit & used a nut & bolt that's still working fine. Altho having the right part is always nice.
