Zap *STILL* wears Depends
You could slide a grade 8 carriage bolt in there with a star washer or tack it in and make it a stud.
Okay, finally finished and what a PIAIt first I tried the Big-Sert 5015 M10X1.5MM Oversized Metric Thread Repair Kit and there was not enough threads on the body frame.I was a little Leary of trying to use the rivet-nuts since I felt the rivet-nut walls were too thin and won't be able to hold the weight and torque of the stability bar.So I went back to what I had before with sliding a bolt inside the body frame channel and fasten it with a star type nut. The funny part original only one side needed the bolt and nut, until the other side I started to tighten one of the original bolt and then it stripped. So now I have 3 with bolts and nuts, and only one mounted with the original bolt that is holding tight.I have question for all,I'm not sure during the time I was putting back the lower A frame the bushing bolt was place feeding inside the A frame housing with the nut on the outside of the A frame housing. Do you think the steering components will hit the bushing threaded end rod where the nut is place?
