Author Topic: Torque spec for Center Link nut and Pitman Arm  (Read 6148 times)
Offline gnonyx
« on: March 11 2021, 05:05:08 PM »
Hi,
Can someone please tell me what is the torque spec for the connection between the Center Link and the Pitman Arm nut?
Thanks
Re: Torque spec for Center Link nut and Pitman Arm
« Reply #1 on: March 11 2021, 05:56:22 PM »
If you download the shop manual, it can really save you a lot of time...altho some times I spend a lot of time trying to find what I want :D
Offline gnonyx
« Reply #2 on: March 11 2021, 08:52:21 PM »
It's funny you mention about the shop manual since I do have the complete shop manual in 4 binders, but there are located on top of the garage shelf where the front end of the car is blocking my access. I do have other in PDF format, but for some reason it's call service manual and it don't give much info, like torque spec.
One more thing Steve, I want to thank you very much for surjection the type of ignition wire you use and I got the Taylor Cable 98024 ThunderVolt 50 Series Ignition Wire Set.
After finishing installing the both headers, and crossover pipe, the engine was running a little rough. I checked both ignition module, and coil pack with new backup and both reading were the same. I also replaced the spark plug with NGK UR4, and now after wires replacement the engine runs good.
Thanks again for the info
« Reply #3 on: March 11 2021, 09:59:42 PM »
Took me awhile to figure out GM called the center link a relay rod.  LOL
Glad the plug wires fixed it!
Here is the link to the factory shop manual where I get so much information including torques from.  http://www.ihadav8.com/forum/index.php?topic=6406.0
Offline gnonyx
« Reply #4 on: March 11 2021, 10:54:10 PM »
I already have that and here is another one I have for many years ago, but you have to use Internet Explorer, as it won't open with Firefox, or Window 10.
 I will Email you
Let me know if work for you or anyone
I created a file folder and place the folder on your Screen, open the folder, place mouse right button on Index.html and open with Internet Explorer.
The one you and I have already is on the right side, and the one on the left is 1986-87 BUICK G-BODY
ILLUSTRATED PARTS HOME CATALOG.
In between both then is trash, and if you look on the bottom of the page it has I believe the creator
It seems this site won't allow me to add a folder only individual files, and most likely it won't go through since one of the files has an exe ext.
Maybe you can see if you any luck adding to this for additional viewers
« Reply #5 on: March 11 2021, 10:55:51 PM »
If you have the factory shop manual, it has all the torques, specs, etc. in it.
« Reply #6 on: March 12 2021, 12:47:44 PM »
Maybe I need to make a video showing how to use the service manual in it’s current format?
« Reply #7 on: March 12 2021, 01:16:49 PM »
Might be a good idea!
« Reply #8 on: March 12 2021, 05:05:49 PM »
Offline gnonyx
« Reply #9 on: March 12 2021, 07:26:19 PM »
https://www.youtube.com/watch?v=eLmgRYYDgek - Try this gnonyx
I appreciate the YouTube, and I do have that service manual, but I don't see the Center Link and the Pitman Arm nut torque spec.
Do you know where the torque spec is located on the service manual?
Thanks
« Reply #10 on: March 12 2021, 07:56:51 PM »
Yes, I gave you a screen shot of part of the page yesterday.it's called a relay rod, not s center link. I will go find it again in a bit
« Reply #11 on: March 12 2021, 08:18:44 PM »
Section 3B6 page 5
Page 2 of 3B6 has a picture of the linkage so I knew I was in the right place and what it was called.
« Last Edit: March 12 2021, 08:22:57 PM by Steve Wood »
« Reply #12 on: March 12 2021, 08:30:35 PM »
The online link to the manual eliminates most of the non turbo stuff and makes it much faster to find what you are looking for
Offline gnonyx
« Reply #13 on: March 12 2021, 10:01:26 PM »
I do understand that part Steve, at first for a couple of seconds is when I realize the relay rod was actually called center link.
My question for nocooler is not needed the making a video showing how to use the service manual in it’s current format, but where in the service manual is the location of the torque spec.
Steve, What you gave me of Section 3B6 page 5
Page 2 of 3B6 has a picture of the linkage is not from the downloaded service manual, but the shop manual which is different than the service manual, or are you claiming it's both the same service manual?
« Reply #14 on: March 12 2021, 10:42:18 PM »
Yes, I took them both from the downloadable turbobuick shop manual which is the edited and scanned original GM shop manual for Buicks.
The first one I posted is screen capture of the part of the page.  You see the box that says torque specs?  45 ft-lbs for the relay rod to the pitman arm.  I believe that is what you asked for.
