Author Topic: Trunk wiring  (Read 1920 times)
Trunk wiring
« on: March 06 2021, 12:10:27 PM »
Restoring the trunk and when I removed the wiring in the deck lid it's got the orange wire for the light, the trunk release wire and a blue wire that goes to this a connector with a white thing....what is the unshielded cable supposed to connect to
Re: Trunk wiring
« Reply #1 on: March 06 2021, 02:05:18 PM »
I am guessing it is there to connect to the anti theft trunk switch
Re: Trunk wiring
« Reply #2 on: March 06 2021, 04:07:38 PM »
Is the little cable wire that comes out of white connector supposed to connect to something, and if so what?
Re: Trunk wiring
« Reply #3 on: March 06 2021, 04:53:17 PM »
Have no idea.  My car with the trunk release is up and  the air and the lift is blocked by my son's wagon.  Neither of my cars have a theft deterrent system.
