Author Topic: Crossover stock pipe bolt size  (Read 4138 times)
Offline gnonyx
« on: January 31 2021, 06:55:08 PM »
Hi All,
Like the title, what size are the bolts for the crossover pipe that gets bolted to the headers?
Thanks
Re: Crossover stock pipe bolt size
« Reply #1 on: January 31 2021, 07:40:37 PM »
M10x1.5 - 40
Offline gnonyx
« Reply #2 on: January 31 2021, 08:10:43 PM »
M10x1.5 - 40
I wasn't sure since the original bolts needs to be replace.
It's funny how 3/8x16 fits, but loose not tight has it needs to be
Can the Hex Head Flange Bolt Non Serrated Class 10.9 also be use for the crossover pipe flange section?
I read there are two types both bolts are the same M10x1/5 40, but one hex head is 14mm. and the other is 15mm both with hex head flange type?
« Last Edit: January 31 2021, 08:23:33 PM by gnonyx »
« Reply #3 on: January 31 2021, 08:22:45 PM »
Go to the Help Section or Display & they should have packages with 3 long & 3 shorter exhaust studs threaded both ends & 3 extra long Brass Nuts. The studs have a square 1/4" end to use for tightening that comes in handy. I've been using them for years & the Brass Nuts work well. Get 2 packs & with 6 of each you can use the Brass nuts on each end if needed.
« Reply #4 on: January 31 2021, 08:27:24 PM »
I don't know,, Julio
Offline gnonyx
« Reply #5 on: January 31 2021, 08:38:47 PM »
I don't know what you're talking about, since these bolts are being use for tighten the stock crossover pipe flange onto the stock headers, which has the nuts are already welded onto the headers.
« Last Edit: January 31 2021, 08:51:48 PM by gnonyx »
« Reply #6 on: January 31 2021, 11:04:49 PM »
If those nuts are stripped, you can use the brass nuts on to of them is what I understood
Offline gnonyx
« Reply #7 on: January 31 2021, 11:49:12 PM »
Thanks for the explanation, I couldn't understand why brass nuts, and no the headers welded nuts are not stripped.
I want to replace both bolt sides with new ones since I have everything all apart.
« Reply #8 on: February 01 2021, 09:32:34 AM »
Steve is right I wasn't very clear but I have some spares in the shop I'll take a pic today, the Brass nuts are extra long maybe
1/2"- 3/4"?? & they come off easily down the road.
Offline gnonyx
« Reply #9 on: February 01 2021, 11:13:19 AM »
Thanks, I do appreciate the definition, but maybe I'm wrong but isn't brass soft material and having that much torque to tighten crossover pipe to the headers the brass bolt and nuts would stripped?
« Reply #10 on: February 01 2021, 11:42:47 AM »
Maybe that's why they are extra long? I tighten until good & snug with a washer/lock washer included & never had an issue since the last time I touched them about 2009.
« Reply #11 on: February 01 2021, 01:33:21 PM »
Factory torque spec is 22 ft-lbs, I believe.  a 10 brass mm nut should not have any problem holding that, I would think...the longer nut would help some as well. Fortunately it does not matter if your welded on nuts are good :)
« Reply #12 on: February 01 2021, 03:29:41 PM »
Everyone just stop touching your Nuts & they'll be fine!  :rofl:
Offline gnonyx
« Reply #13 on: February 01 2021, 04:14:31 PM »
I don't care how old you are, always learning something new Thanks Again :rock:
Offline gnonyx
« Reply #14 on: February 01 2021, 04:21:10 PM »
If only it would stop leaking :013:
