Author Topic: Update on future build  (Read 115973 times)
Re: Update on future build
« Reply #270 on: April 24 2024, 03:12:06 PM »
In that case I wont use that stuff until after the required retorque of the heads Lol. Thank you for the advice! I got the tranny cooler mounted and wired up. No leaks, so I'm happy about that. I'm a little bummed out about my shifter cable and I'm having to shift the gears through the column again. I guess I'll order another one
« Reply #271 on: April 24 2024, 11:10:31 PM »
Factory says 44 lbs-inch which is a very small amount.
It works though. Using cork gaskets, I would glue the gaskets to the head (but not to the valve cover) with RTV and then torque them down to the 44 inch lbs setting using an inch lbs wrench.  Let them set for 12 hrs, or so, and then retorque to the same setting.
Then crank the engine and let it get hot.  Turn it off, let it cool down and retorque again. Check them every day or so for a few days. Should work.
Be sure the ends of the intake are not leaking analso the turbo drain line at both ends.
And the fitting into the block where the sending unit (or gauge) for the oil pressure screws into the block
Offline xracerx13
  • NOT
  • First Methanol Kits
« Reply #272 on: April 24 2024, 11:10:43 PM »
I used Jason's (RJC) thicker valve cover gaskets and they worked for me. Especially for the drivers side.
https://rjcracing.com/product/valve-cover-gaskets/
Joe Tripodi 87 Limited T
« Reply #273 on: April 25 2024, 12:41:34 PM »
The turbo drain line is definitely leaking. That's my next hurdle to clear up. Smh. I switched over to studs which makes the job a little easier but the leak is still present. The drain hose I'm certain I can address.
« Reply #274 on: April 25 2024, 12:44:35 PM »
Those RJC gaskets are really nice. I might try those actually after the retorque
« Reply #275 on: April 25 2024, 01:54:41 PM »
yes, they are
« Reply #276 on: April 26 2024, 06:23:38 AM »
If you're using a cool guy return line...don't. The stocker is ribbed for a reason. Patrick Rubio can tell you why. Jason may have return line gaskets.
« Reply #277 on: April 30 2024, 09:19:18 AM »
My original stock return was beat to hell and I refuse to buy another stock return. Aesthetically it just didn't fit my build. I'll address this issue after I take care of some other things. I got my Wideband installed last night so now my dash is officially complete(after I calibrate my speedo). I'm making a little progress.
« Reply #278 on: April 30 2024, 01:04:39 PM »
I am afraid you may end up regretting not using a stock return line... those aftermarket substitutes don't work worth a damn.  We learn from other people's experiences hopefully
« Reply #279 on: April 30 2024, 10:29:09 PM »
Yeah, but it looks cool!
« Reply #280 on: May 01 2024, 12:11:53 AM »
That it does :rock:
« Reply #281 on: May 01 2024, 05:09:51 AM »
That it does :rock:
A 5 minute talk with Patrick Rubio and he'd grab a stocker and put it back on.
« Reply #282 on: May 01 2024, 10:48:47 PM »
I'll get it figured out. I appreciate the input for sure. I'm getting the downpipe dropped off tomorrow to get it straightened out, and then I can get the exhaust hooked up. So much to do.  :icon_eyes:
« Reply #283 on: May 01 2024, 10:49:15 PM »
So far it's seeming that way. Lol
« Reply #284 on: May 03 2024, 08:52:45 AM »
The engineers got it right with these cars. The only weak link is the transmission.. .and owners that don't comprehend that the electrical/fuel system has to be up to snuff.
