Author Topic: Update on future build  (Read 74009 times)
Re: Update on future build
« Reply #180 on: August 30 2022, 11:01:26 AM »
So it will be running after lunch?
« Reply #181 on: August 30 2022, 11:26:43 AM »
 :rock:
« Reply #182 on: August 30 2022, 01:18:12 PM »
 :rofl: :rofl: :rofl: :rofl:
Not necessarily after lunch, but Saturday is my goal. Bought new vacuum lines, and I may have to source some "T's" because I eliminated the.....EGR stuff? I think that's what that is. Lol. I need to grab a oil pressure gauge for the priming too. I'm hoping for no leaks of course. Today I wont be able to get to it, but tomorrow I'll get the TC bolts in and torqued down so I can put the inspection cover on. I appreciate the support in all of this
« Reply #183 on: August 30 2022, 02:02:41 PM »
Sounds good.  Just eliminate the  line going to the egr solenoid :)
If you removed the actual valve, be sure you seal the hole well...otherwi se it will miss like made if there is a leak there.
« Reply #184 on: August 30 2022, 03:04:19 PM »
There's a block off plate right there.
« Reply #185 on: September 01 2022, 10:41:28 AM »
Eric shuts the EGR off via his chip.
« Reply #186 on: September 01 2022, 09:27:26 PM »
That's what I read somewhere so that's good. I'll research all the vacuum routes because there's seems to be quite a bit. Power steering pump is on
« Reply #187 on: September 11 2022, 01:10:20 AM »
Got the engine primed tonight, and the cam sensor seated properly. The TC is bolted to the flywheel and the inspection cover is on. No leaks were found during the prime so I'm pretty excited about that. We're almost there gents!!
« Reply #188 on: September 11 2022, 08:02:27 AM »
YYYYYYYAAAAAAY YYYYYYYY :cheers: :cheers: :cheers: :cheers:
« Reply #189 on: September 11 2022, 02:05:48 PM »
 :cheers:
« Reply #190 on: September 11 2022, 04:24:56 PM »
Get back out there and fire that thing up!
« Reply #191 on: September 16 2022, 10:28:19 AM »
I'll get it fired up Sunday. Thats the goal. I'm in San Diego on vacation currently. :atbeer:
« Reply #192 on: September 16 2022, 11:17:23 AM »
I am sorry that life is so hard...try to make the best of it.  Maybe next time Hawaii  :cheers:
« Reply #193 on: September 20 2022, 11:12:17 AM »
Good morning gents. I am officially going through the "no start" tree. I'll keep you all posted. I'm taking a mental break as this is extremely exhausting and frustrating. Lol
« Reply #194 on: September 20 2022, 11:25:48 AM »
start with the simple rules to help short cut it
