Author Topic: 87 TR cassette deck won't accept cassettes.  (Read 7730 times)
Offline kjhansen
« on: November 18 2020, 10:33:57 AM »
The tape deck in my '87 TR won't let you push the tapes in.  Not that I have any tapes, but I do have a cassette adapter that lets you plug your phone into the system with the mini-jack.  Any thoughts?
Keith
Offline reality
Re: 87 TR cassette deck won't accept cassettes.
« Reply #1 on: November 18 2020, 11:41:07 AM »
It's possible there is a tape ''stuck'' in there.
« Reply #2 on: November 19 2020, 09:06:54 AM »
Post for a good used one. Would cost you more to fix the one you have.
Offline 85and87turbofun
  • Newbie
« Reply #3 on: November 19 2020, 11:07:36 AM »
Most likely the belt has rotted away.
If the mechanism doesn't move, it burps out the tape.
 It's not that hard to take apart and replace the belt.
You can take the bottom cover off. The cassette deck can
then be removed. Then you take the bottom cover off the deck.
If your belt is broke, you may have trouble routing it right.
Otherwise, note how the belt winds through the pulleys.
You may still be able to match up a belt from MCMinone.com
an electronic supply house.
I bought some years ago, IDK if they still have them.
Offline kjhansen
« Reply #4 on: November 20 2020, 06:37:51 PM »
Thanks for the reply.  I'll check it out.
Keith
