Header Identification
2
Topic: Header Identification (Read 5694 times)
Scoobum
October 12 2020, 12:15:50 PM »
Anyone know what brand of headers these are. Are these the dreaded Hooker headers...cuz I don't recognize these.
Re: Header Identification
October 12 2020, 12:59:26 PM »
The original hookers were ceramic coated. Is there any trace of that left? They also had larger tubes than the factory headers
Scoobum
October 12 2020, 01:10:25 PM »
Steve, it's a guy I'm working with south of the border. Pics are all I have. He was told they're Hookers. I'm thinking the WB is to close to the bend. I remember you told me to install mine a certain distance from the bend.
Scoobum
October 12 2020, 01:15:54 PM »
The chip and injectors arrived from Eric a day or two ago. He went WOT with a chip that was burned for a 49...and he installed a 6262. The PL file was nothing but KR. The 6262 sucked the chip dry.
Scoobum
October 12 2020, 01:26:06 PM »
Steve...he has a pair of stock headers laying around. I texted him to give the diameter of both. I'll update this when he gets back to me.
nocooler
Administrator
Reply #5 on:
October 12 2020, 02:13:39 PM »
Those are hookers Brad.
Scoobum
Reply #6 on:
October 12 2020, 02:19:21 PM »
Thanks so much Jeremy. I'll have him bolt up the stockers he has. This car is a work in progress.
Reply #7 on:
October 12 2020, 06:16:53 PM »
They spooled slower with a given turbo but they ran well once spooled. Only real problem I had with them was the o2 sensor would code 13 after I had stopped for a minute or so...then go away when I took off again. Cooled down fast. Was better without a washer under it. I guess a heated sensor would have fixed that.
A bunch of the faster cars used them.
Scoobum
Reply #8 on:
October 12 2020, 06:56:04 PM »
Steve, here's an idle PL log. Chip is a 6.1 burned for this combo. Fuel pressure was set at 43 PSI line off.
Reply #9 on:
October 12 2020, 10:20:44 PM »
you did not mention what wb and either the o2 is not getting any heat ala hookers, or the o2 is bad as it is not active
ULYCYC
Turbo Street Modified
PSI: 4
Reply #10 on:
October 13 2020, 07:16:21 AM »
I used the Hooker headers for years. As Steve said the O2 went to sleep at idle but a heated O2 sensor cured the problem. Also using the Hooker downpipe cured the slow spool issues. It was a little larger then stock but smaller then most aftermarket ones. I guess a little restriction on the other end balanced things out. At the time stock headers were cracking like saltines and aftermarket ones were too expensive. Hookers were half the price. You learn to work around problems. Today I would go with TA Performance headers or stock ones if you can find them.
Scoobum
Reply #11 on:
October 13 2020, 09:18:29 AM »
TA sells stock replacement headers.
Scoobum
Reply #12 on:
October 13 2020, 09:37:26 AM »
Steve I texted him and asked how old the NB sensor is...and what brand of WB sensor, so he picked the correct one from the drop down box. Waiting on a reply.
Scoobum
Reply #13 on:
October 13 2020, 12:23:18 PM »
Steve, the NB is new and the WB is an AEM. I've asked him to take it for a drive and record a PL log. No WOT cuz he said it had KR with the new chip and injectors. Note on the pic it has an adjustable rod. I got him to back it off...but he doesn't know the boost level. Says he can't get it to work with PL. Pump is from Kirbans and he has it hotwired. Anymore questions...as
k. Just thot. Maybe the boost getting away cuz the wastegate hole is untouched...an
d it's leaning out cuz of that. I had to port my 6262 twice to keep it in check. Oh, and he can't get the boost gauge to work either. We're lucky...at least he's listening.
Last Edit: October 13 2020, 12:38:43 PM by Scoobum
Scoobum
Reply #14 on:
October 13 2020, 12:45:10 PM »
Okay, he has the in car boost gauge working. Having him work on the PL boost now.
2
