Quote from: Scoobum on September 18 2020, 10:25:14 PMReading from Erics forum, you can swap in an 86-87 ECM and use Powerlogger. He also recommends swapping out to an LT1 MAF and Translator. And I'd grab his street chip, if the car doesn't have one. Stock injectors are 28 lb.Okay Thank you fir the info,I was actually thinking of ordering the 37lb injectors from racetronix, but am still unsure. The 86-87 ECM idea is a great idea as well.....man i,m a bit confused. Are there 86-87 ECM's being sold on the site often?
Stock ECM's are a dime a dozen. Go to my Youtube channel. I show how to mod it for PL.
I thought they ran okay without the calpac but Eric is the guy for the absolute answer.I think the problem with the calpac was that when larger injectors were used, the engine would be flooded badly with fuel. Calpac required tps and ignition pulses from the module to let the engine barely run. If the cal pac was not in the computer, the car would not start. I think Eric removed the requirement of having one installed but, like I said, ask Eric to get the straight info. He's a very nice guy.
did you ask Eric if he considers Canada as international?
