Author Topic: Bradys build  (Read 27854 times)
Re: Bradys build
« Reply #15 on: September 22 2020, 03:07:45 PM »
says it needs a non-lock up converter?????
Re: Bradys build
« Reply #16 on: September 22 2020, 04:20:11 PM »
I saw that to...how is that relevant?
Also the "warning" below.....only California  :icon_eyes: :icon_eyes:
WARNING: This product can expose you to chemicals including lead, sulfur, nickel, chromium, vanadium, titanium, polyvinyl chloride, and 4,4’-methylenebis (2-chloroaniline), which are known to the State of California to cause cancer and birth defects or other reproductive harm. For more information go to www.P65Warning s.ca.gov.
you
Re: Bradys build
« Reply #17 on: September 22 2020, 04:33:15 PM »
Might call Hwy Stars and ask if they know when they will get another batch
Re: Bradys build
« Reply #18 on: September 23 2020, 04:34:33 PM »
Highway Stars doesn't know if they're going to get any more, opgi has a length of 37 in which is too short....as far as I can't tell no one has the correct length for a turbo buick. I might have to figure out how to make one of these "universal" length ones work.
Re: Bradys build
« Reply #19 on: September 23 2020, 04:44:47 PM »
Maybe call a couple of the builders and ask what they are using?
Re: Bradys build
« Reply #20 on: September 23 2020, 08:13:12 PM »
universal ones require a pressure gauge to set.
Like Steve said - call a couple 2004r builders. Vince Janis out of akron ohio always treated me right.
Re: Bradys build
« Reply #21 on: September 23 2020, 08:21:14 PM »
Thanks guys!!
Re: Bradys build
« Reply #22 on: September 25 2020, 08:01:08 PM »
cleaning up underside, before and after
Re: Bradys build
« Reply #23 on: September 25 2020, 08:03:55 PM »
also got the brakes cleaned up and bled system...brake s done!!
Re: Bradys build
« Reply #24 on: September 25 2020, 09:06:50 PM »
Wow it’s cleaning up really nice!
Re: Bradys build
« Reply #25 on: September 25 2020, 11:30:14 PM »
No Kidding!!  that looks great!  You and your son need to come spend some time with me!
Re: Bradys build
« Reply #26 on: September 26 2020, 03:00:24 PM »
Going to focus on getting it started now. It appears that the IAC has a aftermarket spacer the turns it from pointing straight ahead to a 45 angle over the cam sensor? What's the advantage, as it is in the way for setting the cam sensor?
Re: Bradys build
« Reply #27 on: September 26 2020, 03:08:34 PM »
The Iac angle boss adapter was so you have more room to run a bigger inlet tube.
Re: Bradys build
« Reply #28 on: September 26 2020, 03:17:30 PM »
Thank you!!
Re: Bradys build
« Reply #29 on: September 27 2020, 02:31:36 PM »
Trying to sort out the wiring, not my strong suit. So much stuff has been hacked into over the years. Mark has the engine bay really sorted out but under the dash has me overwhelmed. What is the attached picture? Can't find anything that looks like it should plug into it under here
