Zap *STILL* wears Depends
Bradys build
Pages:
6
7
8
9
10
12
Topic: Bradys build (Read 33001 times)
Re: Bradys build
Reply #105 on:
October 10 2020, 05:41:22 PM »
He's right, but let's not lower it until we can get the O2 up, and keep the maf down around 6
reality
Turbo Street Modified
Boost n00b
Re: Bradys build
Reply #106 on:
October 10 2020, 09:03:42 PM »
If you lower the fuel pressure wouldn't that create a leaner mixture and therefore the o2's would rise?
My 3 in maf always idled at 7. I didn't worry about it.
Shimy87
PSI: 2
Re: Bradys build
Reply #107 on:
October 14 2020, 04:56:56 PM »
Well, with lots of help and lots of part swapping got it sorted out! turns out the translator was bad, and the powerlogger was bad also. 2 faulty electronic items make a guy want to lose it!! its a bummer about the PL as they are awesome to have! Also after bleeding the brakes 3 times figured out the master cylinder was bad. Replacing that tonight and then she will make a maiden voyage around the driveway. Cant really drive it yet as in search of an elusive TV transmission cable. Progress!!!
Re: Bradys build
Reply #108 on:
October 14 2020, 06:11:07 PM »
Bob will fix the PL for you, I think. Tell him what you found and ask him if he will look at it for you👍
Scoobum
Re: Bradys build
Reply #109 on:
October 14 2020, 07:48:05 PM »
This is the first I've heard of a bad PL or Translator.
Shimy87
PSI: 2
Re: Bradys build
Reply #110 on:
October 14 2020, 09:15:49 PM »
I'm just lucky I guess:)
Shimy87
PSI: 2
Re: Bradys build
Reply #111 on:
October 23 2020, 04:27:20 PM »
Trying to sort all my cooling fan problem. If I ground the temp sensor wire that is directly under the throttle body with the key on I thought that should make the fans come on but it does not?
The fans do work because I've been turn them on manually with a switch direct wired
Re: Bradys build
Reply #112 on:
October 23 2020, 07:03:15 PM »
I'm not sure how those fans are wired. Here is a write up I did on the factory wiring which might help sort the factory side out. It is quite possible that a relay or relay is bad. This might help you figure that out ??
http://www.vortexbuicks-etc.com/fan.htm
Last Edit: October 23 2020, 07:07:23 PM by Steve Wood
Shimy87
PSI: 2
Re: Bradys build
Reply #113 on:
October 27 2020, 05:28:51 PM »
Update time, got the fans figured out and the snow melted off the road so we took it out for the maiden voyage. It runs okay it holds first gear forever so I think I have to adjust that TV cable better, the alternator must not work because it only puts out 10 and 11 volts when it's running so I'm sure it's just getting that off the battery. Still has a terrible stumble when you Goose the throttle I think maybe I need new injectors and it certainly does not like boost. But other than that put about 5 miles on and I got us back home in one piece so I'll take that as a small victory and keep trying to work the bugs out
Scoobum
Re: Bradys build
Reply #114 on:
October 27 2020, 05:59:17 PM »
Check the voltage at the back of the alternator.
Re: Bradys build
Reply #115 on:
October 27 2020, 09:00:33 PM »
Does the volt light come on when you turn the key on?
Move the cable one click.
Check the fuel press to see if it is behaving properly.
Shimy87
PSI: 2
Re: Bradys build
Reply #116 on:
October 27 2020, 09:12:09 PM »
Do I move it one click towards the firewall, as in if 4 ribs show, make 5 show?
Also going to pull injectors and try the you tube bench cleaning method with a spray can, some tubing, and clicking power to them till I get a nice spray
Re: Bradys build
Reply #117 on:
October 27 2020, 09:33:31 PM »
Toward the firewall as I recall
Shimy87
PSI: 2
Re: Bradys build
Reply #118 on:
October 28 2020, 02:09:20 PM »
well tried the at home injector cleaning, didnt go well. cycling power or ground would not open the injector??? Had to drop them off to be professionally cleaned...$150
Re: Bradys build
Reply #119 on:
October 28 2020, 02:24:40 PM »
in my opinion, it is worth it even if it seems about 50 bucks too high
Pages:
6
7
8
9
10
12
Bradys build
