Author Topic: Heater Core Cover?  (Read 3889 times)
Heater Core Cover?
« on: September 06 2020, 03:41:48 PM »
So Ray & I have been following Steve's instructions on vortexbuickset c.com & it was going way too smoothly until the gremlins showed up. I can lift up the cover of the case 1"-2" all around the front, middle & sides easily but right in the centre against the firewall it won't budge? Not Up, Down, Left or Right? Looking over the pics & instructions we did Not remove the 4x 12mm nuts & 2 brackets for washer trim support. I don't see how they would stop it but something is blocking it? Any ideas? :chin:
Re: Heater Core Cover?
« Reply #1 on: September 06 2020, 04:45:09 PM »
I went back at it & success it's off! The issue was the weather stripping just holding hard back & centre. Now I looked at the heater core & I'm not sure it is the problem? I blew some air in & put my finger on the other tube & it seems pretty tight so maybe its not the problem? I have a new one on the way so it's going in but I'm now in need of a line on Weather Stripping for firewall.
Also which Sealer I can use? Black RTV? Right Stuff would be impossible to open in the future. Thanks
« Reply #2 on: September 06 2020, 04:45:53 PM »
Under the air intake screen there are more screws.  Don't remember if its 2 or 3
« Reply #3 on: September 06 2020, 05:08:33 PM »
Thanks Ed I originally did miss one of them but it was sealed so well from the factory we were both pulling on it to finally get the thing out. They did a good job of sealing it.   :icon_eyes:
Offline 1KWIKSIX
« Reply #4 on: September 06 2020, 05:38:14 PM »
Offline 1KWIKSIX
« Reply #5 on: September 06 2020, 05:41:10 PM »
RMI-25 is good stuff, however will find any weakness in your cooling system .
i suspect you’re Heater core was marginal and the application of RMI-25 did its job and found some problem areas and now it’s leaking. I’ve heard it doing the same on radiators too if their not in tip top shape
« Reply #6 on: September 07 2020, 10:01:06 AM »
Quote from: 1KWIKSIX
Thanks Dave now I know what to look fo.r I've used the RMI 25 for years but I flushed it twice before the new rad went in & maybe it exposed the leak a little more.
« Reply #7 on: September 08 2020, 01:52:43 PM »
This stuff is what the factory used to use or very similar to it. ordering some up later today.
3M 8578 Strip Caulk, (3M-SCB)
When I put up the link I get Access denied I have an Amazon link but it shows my info but it looks like good stuff.
« Last Edit: September 08 2020, 02:01:47 PM by Just a Six? »
« Reply #8 on: September 12 2020, 04:52:09 PM »
Ok so made some progress with the heater box cover it's all cleaned up & I'm now looking for the Long Foam 2" wide strip with the 4 holes that goes on the firewall so if anyone has any idea where to find one it would be Greatly Appreciated.  :cheers:
Also I have the Spectra Heater Core & it has some foam strips on the side but it's still a bit on the small side. Thinking I have some old intercooler & MAF rubber connectors so maybe I'll cut those up if I don't find an alternate solution? Any other ideas?  :chin:
