Author Topic: Power Steering Pump Noise  (Read 3117 times)
Offline Recap
« on: August 29 2020, 11:23:08 PM »
So power steering pump is making a lot of noise.  I did have the high pressure line off to replace the o-ring.  Is my pump shot or do I just need to bleed the system again?  Drove it about 10 miles and it's still making excessive noise.  The reason I replaced the o-ring was it was losing a little fluid and seemed to be letting in a little air when it sat for a week or two.  Pump was then making a little noise until I turned a few times then was ok. Any thoughts?
Re: Power Steering Pump Noise
« Reply #1 on: August 29 2020, 11:43:30 PM »
Jack the front up so the wheels are off the ground.  Crank it up and turn it slowly lock to lock a few times.  See if that gets the air out.
Offline Recap
« Reply #2 on: August 30 2020, 09:51:11 PM »
Thanks for the suggestion Steve.   Did the high pressure hose o-ring a while back and thought I had done this but maybe not.  I'll give that another try and see what happens.  What do you use for fluid, atf or ps fluid?  I think I topped it off with ps fluid after the repair.
« Reply #3 on: August 31 2020, 10:16:55 AM »
think I used PS Fluid the last time I messed with it
Offline Recap
« Reply #4 on: September 06 2020, 10:49:00 PM »
Well think my problem is solved.  Reservoir was low on fluid.   Could swear I filed it and bleed the system when I was done replacing the ps hose o-ring. It was a few months ago so who knows.  It's back to normal so I can know get it to the shop for a front end alignment as I did the b body spindle swap several months ago.  Think I'm going to have to bleed the brakes again though as they still seem a little soft.
