Author Topic: Help with knock log included  (Read 6503 times)
Offline Robjob
« on: August 13 2020, 10:19:22 PM »
I'm getting some weird knock with a gn I just picked up. Short story is I picked up this gn and after going thru it and replacing what leaked or didn't work I pretty much brought the car back to stock engine wise. Once everything seemed fine I started to check out all the parameters and everything checked out on the powerlogger. Right now what I have is a stock turbo, stock fuel pump no hot wire kit, stock injectors, lt-1 maf with translator. I didn't mention the chip because I had a chip with the same engine parameters as what I have the only thing different is that the chip was burned for a lock up transmission and torque and I have a extreme automatics stage 2 non lock up with a 2800 stall non lock up torque attached to the engine because the stock one gave out so I put this one I had for my other gn in it. Now to the knock issue. The car idles fine and even drives fine at low speeds and gears. Everything parameter wise is also fine when cruising around town. However when you decide to get in it it will pick up and boost strong for a little bit then when it seems like it should either swithch gears or just keep pulling all of a sudden it starts to knock retard and act like it won't pull or shift anymore. I've included a log hopefully its not to long.
Re: Help with knock log included
« Reply #1 on: August 13 2020, 11:36:09 PM »
Weird shit going on. MPH isn't reading. Frame 810 to 894 tells me you have a lean fuel issue with barely running any boost. Timing looks to be high in high gear as well. My guess is it's going lean and falling on it's face. What chip is in  it? Is it set correctly with the Translator?
Offline Robjob
« Reply #2 on: August 13 2020, 11:46:42 PM »
The mph is not working I think do to the cable every since I went to the stage 2 tranny it stopped working thinking. Right now I have a tt chip 5.7 set for stock boost, injectors, and fuel pump. The only thing different is the transmission deal.
« Reply #3 on: August 13 2020, 11:57:40 PM »
The MPH has to be working for certain features in Erics chip. Contact Eric. I'm seeing it going lean in the frame numbers I posted at low boost. Make sure the timing is on its defaults.
« Reply #4 on: August 14 2020, 09:17:04 AM »
Fix the speedometer.  Make sure it has the driven gear installed in the "bullet" that sticks in the side of the transmission (the cable screws onto the "bullet").  Pull it out and there should be a gear inserted on the other end.
Offline Robjob
« Reply #5 on: August 14 2020, 12:45:23 PM »
Ok I definitely will fix the speedometer either today or tomorrow.
Offline Robjob
« Reply #6 on: August 15 2020, 06:50:39 PM »
So I have fixed the speedometer and took two more logs. The first log was me taking off out my driveway. The second log is on the freeway. At part throttle it seems to pick up great and pull and go. However, as soon as I stomp down it knocks, runs thru my knock sensor lights like a champ so I just lift. It goes away and once again able to pull hard at part throttle.
« Reply #7 on: August 15 2020, 08:20:21 PM »
Looks like a bad motor mount-probably drivers side.  Or a loose exhaust that is moving and banging into the body...check the transmission mount as well
« Reply #8 on: August 16 2020, 11:36:49 AM »
3rd gear isn't showing. Is this chip burned for the exact combo you're running?
« Reply #9 on: August 16 2020, 03:13:47 PM »
I am thinking that Eric does not use either the third or fourth gear switches.  I believe the factory used them for egr.
« Reply #10 on: August 16 2020, 08:53:30 PM »
The supply the ground for the TCC
« Reply #11 on: August 16 2020, 09:21:29 PM »
Nope, that is provided by the ecm
http://www.vortexbuicks-etc.com/tcc_lockup.htm
As I understand it, the egr can only be in effect when the car is getting a signal from the third and fourth gear switches in the valve body and the converter is locked which means the car is cruising at light load.  Since the modern chips remove the egr function, it matters not whether the switches are working.
They don't affect the actual converter lock up.
« Last Edit: August 16 2020, 11:24:29 PM by Steve Wood »
Offline Robjob
« Reply #12 on: August 17 2020, 08:49:21 PM »
As far as the chip it is sorta  burned for the set up, I will explain. It is not the specific chip for the set up. The chip was burned for stock fuel pump, stock injectors, stock lock up tranny, and torque. Everything is true except for the transmission. The transmission is a non lock up stage 2 tranny, with a non lock up 2800 stall torque.
« Reply #13 on: August 18 2020, 02:36:08 PM »
Quote
I'm pretty sure the ground path inside the ECM come from the switches.  It's been years since I looked at the internal schematics.   The image on your page just shows that it is a ground inside the ECM on the TCC circuit, it doesn't show where it gets the ground.
And they 100% control TCC lockup.    On my original transmission, I had a flaky igntition feeling on the interstate and it was the TCC rapidly unlocking and locking back up.  New switches fixed that.
  When my car sat after being stolen, my new Dynatech transmission lost both it's switches while sitting (which is very odd considering they're NC switches).  They just miraculously went to open.
  Two new switches restored the TCC and the powerlogger could see the gears again.
« Reply #14 on: August 18 2020, 03:16:06 PM »
 :cheers:
« Last Edit: August 18 2020, 03:37:07 PM by Steve Wood »
