Author Topic: ac compressor plug?  (Read 2170 times)
Offline shmed
ac compressor plug?
« on: August 08 2020, 04:09:51 PM »
ok. there's a. 2 prong plug at the front bottom of the compressor   I believe its for the clutch to lock up. anyways which way does the connector go on?  there's a green wire and a black
thanks
Re: ac compressor plug?
« Reply #1 on: August 08 2020, 04:59:08 PM »
http://www.vortexbuicks-etc.com/ac_compressor_electrics.htm
The clutch connector is green and black as you said.  The black side goes to ground thru the high pressure switch on the compressor as the diagram shows on the diagram.  That switch should normally be closed so you can find ground with your meter.
The connector that goes to the compressor should have a diode wired across it as shown on the diagram.
