Author Topic: Boost Gauge - LED Indicator  (Read 2768 times)
Offline rgfullerton
  • Newbie
« on: July 27 2020, 09:25:30 AM »
anyone know the meaning of the LED Indicator just to the left of my Pillar Mount Boost Gauge?   It glows either Green, Yellow, or Red.  When I brake torque it comes on red at ~ 8lbs boost
Re: Boost Gauge - LED Indicator
« Reply #1 on: July 27 2020, 10:47:43 AM »
Can you take a picture of it and post it? Almost sound like a knock detector.
« Reply #2 on: July 27 2020, 03:30:03 PM »
Possible an alky light.  Or something connected to a hobbs switch like a booster pump or some other hack.
« Reply #3 on: July 28 2020, 10:57:08 AM »
I think an alky light also
