The Bastard Child Buick Board
engine only runs with MAF disconnected
2
Topic: engine only runs with MAF disconnected (Read 8629 times)
Gerry17
Bone Stock
Boost n00b
July 20 2020, 07:59:58 AM »
hello everyone im hoping someone can help me diagnose my issue. MY car will not run with the MAF connected. new LT1 maf and translator, ecm, air temp sensor, ignition module and coil. tested my grounds at the ecm and all ok. checked for vacuum leaks nothing found. BLM at 128 fuel pressure holding steady at 40 psi. it will load up and stall as soon as I connect the maf sensor..load tested the maf circuits and all passed. any help will be appreciated.
Re: engine only runs with MAF disconnected
July 20 2020, 10:41:28 AM »
that one is a new one on me.
When the maf is connected and you turn the key on, what does the maf read on your scantool (don't start the engine)
After looking at that reading, crank the car and look at the maf reading again with the engine idling. What does that read?
Also, does it throw a trouble code when it is running?
Gerry17
Bone Stock
Boost n00b
July 20 2020, 10:47:14 AM »
I will check at lunchtime on the readings. there aren't any codes only a 34 because of the maf being disconnected
Top Speed
Don't Tread on Me
PSI: -2
July 20 2020, 11:18:20 AM »
All settings correct on the translator?
Champion Irons w/T&D roller rockers, TA-61 turbo, 206/206 Comp Cam, 57 lb/hr Siemens Injectors, 3000 stall PTC, PTE Plenum w/RJC Power Plate, 70 mm Accufab Throttle Body, RJC 325 Megacooler, TurboTweak 5.7/ Alky Control w/M1 methanol, 23 psig on the street, Puddn' Power engine, Borla Exhaust
July 20 2020, 11:19:55 AM »
also, are you using a TurboTweak chip or something else?
Gerry17
Bone Stock
Boost n00b
Reply #5 on:
July 20 2020, 11:24:00 AM »
Yes turbo tweek chip and double checked my settings on the translator
Gerry17
Bone Stock
Boost n00b
Reply #6 on:
July 20 2020, 12:44:48 PM »
Just checked my MAF sensor readings and it's at 3 g/s with keep and doesn't change when its running. ⁷
Gerry17
Bone Stock
Boost n00b
Reply #7 on:
July 20 2020, 12:59:22 PM »
with key on its at 3g/s
Reply #8 on:
July 20 2020, 03:49:03 PM »
Then there appears to be a problem with either the maf, or the translator.
It should read 5 or 6 at idle when the engine is idling. 3 is correct with key on, engine off.
You might ask Bob Bailey for an opinion on how to tell which is bad if you don't have access to another maf to try.
Gerry17
Bone Stock
Boost n00b
Reply #9 on:
July 20 2020, 03:53:28 PM »
it was doing the same with several stock units. but I will definitely look deeper into it. Thank you
Reply #10 on:
July 20 2020, 05:18:21 PM »
then that seems to be another problem. Have you checked the continuity of the maf wire back to B6 on the ecm? It would then seem to me that the maf signal is not getting to the ecm or that the ecm itself has a problem
http://www.vortexbuicks-etc.com/ecmwiring.htm
I would also make sure the maf ground wire is good, but, it sounds to me like the ecm is not getting a signal...
Gerry17
Bone Stock
Boost n00b
Reply #11 on:
July 20 2020, 06:27:37 PM »
I just checked the MAF circuits again. according to the shop manual I should have 2.50 volts at B6 terminal at the ecm key on engine off and 2.48 volts engine running. I have 5 volts at the terminal. any idea what the correct voltage should be?
Gerry17
Bone Stock
Boost n00b
Reply #12 on:
July 20 2020, 06:31:06 PM »
I also replaced the ecm with an ac delco unit
Reply #13 on:
July 20 2020, 07:07:09 PM »
well, heck.
The ecm connector show a yellow wire going to B6 along with the voltages, you mention.
The maf sensor page 21-2 shows it to be a gray/red wire. Not the only discrepancy I have seen but as long as you are on B6, that should not make a difference. I don't have a car with a maf on it so I cannot go check it. Those voltages in the manual are not always what I have found but I cannot confirm it.
The maf ground is black/wht and the power from the fuse/key is Pink/black
I have no idea what is happening but it sure looks like it is not getting a maf signal. When you start it up, and rev the engine, does the maf reading move off 3?
Normally, in these cases, I disconnect the ecm connector, put my meter between the correct terminal and the terminal on the maf end and see if I read 0000 ohms on my meter to demonstrate continuity.
Do the same thing between terminal c on the maf connector and the battery negative terminal to confirm the maf ground and also verify battery voltage on terminal A of the maf connector.
If all that checks out, then I ask Bob LOL. Maybe it is just coincidence that factory mafs and the translator are both doing the same? But I would not spend money on that bet without talking to Bob.
I was guessing it was the ecm but you have shot that guess down in all likelihood.
Gerry17
Bone Stock
Boost n00b
Reply #14 on:
July 20 2020, 07:17:09 PM »
I tested all 3 circuits and even did a load test to eliminate and any issues. the wire at b6 is a grey/red wire and I have 5 volts at it all the time. as soon as I plug in the connector the engine starts to spudder and stall, the maf readings stay at 3 g/s. I have been messing with this for 3 weeks and it gets expensive when you just throw parts at it lol. I appreciate your help. I think my issue is elsewhere but its affecting maf.
2
