Author Topic: Coil or Module on Power Logger?  (Read 13324 times)
Offline wmsonta
  • Turbo Street Stock
  • PSI: -1
Re: Coil or Module on Power Logger?
« Reply #30 on: August 30 2020, 11:47:08 AM »
it just smelled like Gas real strong.
When I started mine, it had set for 23 1/2 years. Probably not started for 2-3 yrs. It started right up and was rich as hell.
Because it would not hold fuel pressure, I changed out a new pump. It turned out unnecessary.
I pulled the injectors and sent them to Injection Connection. They test every injector they get. Mine all failed every test. My injectors have not been available for over a decade, so mine were rebuilt, flow matched and tested. The tests before/after are included w/injectors.
My have only good to say about them. They were recommended by a life long friend who is into competition turbo v8's.
« Reply #31 on: August 30 2020, 02:28:34 PM »
I think that my 12 year old 60lb injectors will be my next step after rechecking the Axis, checking resistance on new coil & module & seal up the lines to the heater box. I just took a quick look & realize the hoses are different size so not sure which way I'll go on that yet.
My Mom called & I have some family stuff that's going to sideline me for a bit but I will post back with progress.
Thanks for all the help I appreciate it.   :cheers:
« Reply #32 on: August 30 2020, 02:58:17 PM »
Hope your Mom is okay!
« Reply #33 on: August 30 2020, 04:16:09 PM »
Thanks Steve
Offline wmsonta
  • PSI: -1
« Reply #34 on: August 30 2020, 09:08:11 PM »
  Just a Six
The guy at Injection Connection said that injectors that had set as long as mine were nearly always bad. He said that used injectors out and on the bench are good for days or weeks only. He said the next time mine sets to build pressure in the system once a week. Or try to.
« Reply #35 on: September 01 2020, 12:44:40 PM »
Well I'm sure mine are questionable since the car sits 7 months a year & then is only driven less than 2K kilometers a year lately & they are 60's that are about 12 years old. When I get some time I'll find some heater hose to bypass the heater core then I'll go for a decent drive & check the plugs again but injectors are on the to do list for sure so thanks for the info.
Thinking I'll get rid of the 2 pipes to heater core for now if I can find what I need later on when I have time.
« Reply #36 on: September 01 2020, 04:19:54 PM »
http://www.vortexbuicks-etc.com/heater_core_replacement.htm
Jeremy, why are the links coming out so small?
« Reply #37 on: September 01 2020, 07:57:00 PM »
Steve you can't cut n paste but I opened it in a new window & went right to your site with heater core info.
So I saw your pics of the R&R I need to open it all up first & then order the parts.  Thanks Steve!  :cheers:
« Last Edit: September 01 2020, 08:11:17 PM by Just a Six? »
« Reply #38 on: September 01 2020, 10:33:28 PM »
it's a pretty easy job.  Just get all the bolts out LOL
« Reply #39 on: September 02 2020, 08:10:43 PM »
Highway Stars is out of stock on Heater Cores https://www.highwaystars.net/heater-core-aluminum-replaces-gm-s-3037689-52479872/
Rock Auto has the OSC 98505 with the padded edges it looks like for $27.
They also have the APDI/PRO 9010089 (3037689) for $28 but no padded edges. Some sizing info is supplied.
Also the TYC 96025 (3037689) for $31 it has some kind of added bracket & info on sizing.
Any thoughts on which way to go?
I should have some time mid month or maybe sooner to do the swap.
 https://www.rockauto.com/en/catalog/buick,1987,regal,3.8l+231cid+v6+turbocharged,1020957,heat+&+air+conditioning,heater+core,6864
« Reply #40 on: September 02 2020, 11:09:28 PM »
Quote from: Steve Wood
It's the editor in the forum software - I just haven't had a chance to get to it. Kids are back to school now, my plates still pretty full but I'll see what I can do.
« Reply #41 on: September 03 2020, 09:11:40 AM »
You will have less time when they close the schools and send the kids back home for remote schooling! LOL
If you get time, also look at the picture scaling as shown above in my posting of David's pictures..
« Reply #42 on: September 03 2020, 10:10:41 AM »
Pretty much why I'm busting ass to get stuff done while I can.
« Reply #43 on: September 03 2020, 08:54:17 PM »
« Reply #44 on: September 03 2020, 08:54:38 PM »
that one worked :)
